Author Topic: General Resistance RTD-100 Teardown and repair.  (Read 3688 times)
Online VgkidTopic starter
« on: October 06, 2018, 04:37:14 pm »
I have always wanted an rtd calibrator / milliohm box. Well it finally happened , and here is what I got...
I will apologize , my pics didn't turn out too well. I can't use my lab(packing stuff up , to move it into the unheated garage) plus my mom is recovering from knee surgery , don't want to risk it.
I included a variant image of this unit.
« Last Edit: October 07, 2018, 01:58:31 am by Vgkid »
The following users thanked this post: doktor pyta, mnementh
Re: General Resistance RTD-100 Teardown and repair.
« Reply #1 on: October 07, 2018, 05:05:25 am »
For this , the tear down will be first , and a short overview on the theory will be later.
**I will add a few more pics as I go through the unit**
After seeing the outside of the unit , lets look at where the output terminals should be.
We are presented with one gold binding post , most likely a Pomona 3770. The other 3 binding post are missing , they look to have been cut  from their wires. The binding post sense leads are connected to the source leads by a gold binding post link( judging from other pictures)
The first 3 decades follow the conventional decade resistor layout , except the '1' position on the 10-Ohms range is its lowest setting. The resistor for this represents the difference between 10 Ohms , and the rest of the lower shunted mill-ohm values.
The milliohm range represents a large shift in the expected values in a decade resistor. These occur by shunting a resistor , with varying resistors in series. This will give a range that will increment by a desired amount.    This will be explained more later.
Offline bitseeker
« Reply #2 on: October 07, 2018, 05:20:48 am »
Cool. Following along...
« Reply #3 on: October 07, 2018, 01:58:32 pm »
Some fuckwit defiled a laboratory-grade resistance box with dikes to harvest $6 a few $$ worth of banana jacks...
Where is the [Punch him in the DICK!!!] button on my keyboard? I need it RIGHT NOW!!!
Don't forget to use silver-bearing solder when you restore; keep it as original as possible.
« Last Edit: October 08, 2018, 03:50:30 pm by mnementh »
« Reply #4 on: October 07, 2018, 06:51:23 pm »
Unless that other banana jack is able to be cleaned , I will need to grab  4-3770 thats like 45bucks. I can't wait to test it.
Offline Kosmic
« Reply #5 on: October 07, 2018, 07:09:59 pm »
There's also the Mueller BU-P3770. Supposed to be similar to the Pomona but cheaper. You can find them on arrow for 8$ shipping included.
« Reply #6 on: October 07, 2018, 09:32:46 pm »
I see digikey stocks them , might need to add them to my resistor order.
Arrow is a painful site to use , if you don't know part numbers. >:(
Offline bitseeker
« Reply #7 on: October 07, 2018, 10:10:14 pm »
Yep, it sure is. But sometimes (not always) they have the best price. The free overnight shipping is nice as well.
« Reply #8 on: October 08, 2018, 03:54:33 pm »
Crap. I had no idea they were that expensive now.  :palm:
Good single-contact jacks like that were a couple bucks from ECG; I figured that thing was probably coeval with them.
*Sigh* I sound just like my grandmother... "Kids are fuckwits. Cars are ugly. Stuff costs more."   |O
« Last Edit: October 08, 2018, 03:56:04 pm by mnementh »
Offline Kosmic
« Reply #9 on: October 08, 2018, 04:18:52 pm »
Copper is expensive now. Brass binding post are cheaper.
« Reply #10 on: October 09, 2018, 02:19:54 am »
Filed a small amount off the end of the binding post , and it looks to be gold plated brass. I will tell more tomorrow. I will also get some better pics , hopefully. taking pics out side.
Correct , gold plated brass .
« Last Edit: October 10, 2018, 02:14:18 am by Vgkid »
