Author Topic: low drift low noise current source  (Read 4915 times)
Online maat
Re: low drift low noise current source
« Reply #25 on: March 16, 2023, 11:19:28 am »
The singlemode 0.1 pm target is easy to hit. I will look up the numbers on our ECDLs to give you a ballpark figure
That would be very much appreciated.
ECDL: external cavity diode laser?
ECDL = external cavity diode laser
Regarding the linewidth, we typically use a self-heterodyne beat. So we split the beam and sent one side down a 25 km fiber, then superimpose the beams again. That way, we measured our 960 nm lasers to have a free-running linewidth of 25 kHz @ tau = 120 µs limited by mechanical resonances. The external resonator is a 60 mm aluminum block. Send me PM if you want to know more (publication is pending). The 25 kHz is what you get with a very good diode driver (in-house dev., publication pending) and it is not limited by the driver, but rather the environment. Spoiler: Toptica is way above 100 kHz (depending on the generation of laser and driver of course), but your target is closer to several MHz, so don't sweat it.
Edit: I just remembered, that the LT1128 is using a bias current cancelling circuit. So try to match the source resistance when working with an input impedance of more than 1k. See p. 6 of the LT1128 datasheet.
« Last Edit: March 16, 2023, 01:41:30 pm by maat »
The following users thanked this post: Andree Henkel
Online zrq
« Reply #26 on: March 16, 2023, 08:13:32 pm »
What's your ECDL's mode-hop free tuning range?
Looking forward to read your paper, especially the part for the diode driver.
Online maat
« Reply #27 on: March 17, 2023, 07:45:58 am »
Typical values for our 780 nm diodes is something like 1 Ghz. Example diodes are Sharp GH0782RA2C or Thorlabs L785H1. Some individual lasers are better than that and may have up to 2 GHz. AR-coated diodes (of which we only use a few) can do something like 10 Ghz. Blue laser diodes are a lot more finicky and typically have about 500 MHz or less.
Our Application is more focused on stability. Therefore we use filter based lasers and no gratings.
« Last Edit: March 17, 2023, 06:02:51 pm by maat »
Offline Andree HenkelTopic starter
« Reply #28 on: March 17, 2023, 10:02:46 am »
Looking forward to learn about the current source part too.
My Driver is intended to drive a 405nm diode, tuning is not intended. Just trimming temperature and current in combination to get mode hop free operation at desired power.
