Author Topic: Geller Labs site finally gone, contents capture  (Read 2823 times)
Offline GyroTopic starter
« on: March 21, 2019, 06:13:26 pm »
It looks as if Joe Geller's lab site has finally been taken down, not surprising as it had been lingering (minus some files and images) for a least a couple of years longer than he indicated.
I thought it might be a good idea to start a thread to try to capture as much archived stuff from the site as possible. Contributions welcome.
I have a reasonable amount of stuff relating to the SVR / SVR-T and a few other bits but I never downloaded his LM399+AD587 reference (I only have the patent file), Micro-gust anemometer, Resistor Noise measurement, Magnetometer (?), Investigation into small value AC measurements on HP DMMs etc.
I've attached what I have anyway (all ZIPs, include HTML files(Firefox) and jpgs:
- SVR SVR-T Winding Down  -  Construction information, including temperature compensation text from Lars, and thought about winding down the lab.
- SVR Temperature Coefficient Setup - The test rig he used for characterising SVRs and SVR-Ts, including pictures.
- 10 1 Reference Divider 752 Junior -  His experimental Hamon divider. Missing bottom view and XLS file.
- 6 1_2 Digit DMM Temperature Coefficients - His 61/2 digit temperature coefficient measurement page (missing all attachments).
- Misc PDFs (self explanatory)
As always, use your own cautions when opening files!
Other contributions welcome.
« Last Edit: March 21, 2019, 06:35:14 pm by Gyro »
Best Regards, Chris
The following users thanked this post: quarks, dr.diesel, e61_phil, doktor pyta, mycroft, BU508A, 2N3055, alm, JoeRoy
Offline edpalmer42
Re: Geller Labs site finally gone, contents res
« Reply #1 on: March 21, 2019, 06:20:38 pm »
The Internet Archive seems to have all the content.  Is it worthwhile to duplicate that here?   :-//
https://web.archive.org/web/20130607180940/http://gellerlabs.com/
Ed
The following users thanked this post: quarks, doktor pyta, Gyro, BU508A
Re: Geller Labs site finally gone, contents capture
« Reply #2 on: March 21, 2019, 06:36:40 pm »
Ah, good thought, Thank you. It hadn't even occurred to me that it might still be available there!  :palm:
EDIT: Although it seems to be missing some of the same JPGs as I am.
« Last Edit: March 21, 2019, 06:57:54 pm by Gyro »
Best Regards, Chris
Offline edpalmer42
« Reply #3 on: March 21, 2019, 06:56:42 pm »
I always check the Internet Archive when I come across a broken web page or a link to a shutdown site ........ unless I forget ..... :-[   ;)
Ed
