Author Topic: Optical probe for oscilloscope  (Read 1518 times)
Dave92F1
  • Guest
« on: May 05, 2020, 08:17:56 pm »
Back in January Elektor published a "Optical Probe for Oscilloscopes" project: https://www.elektormagazine.com/articles/optical-probe-for-oscilloscopes
It's a photodiode with a couple of op-amps.
My question - how is this better than just hooking a photodiode (or small solar cell) directly to an oscilloscope?
I've successfully measured video latency with small solar cells and an oscilloscope - CH1: solar cell and camera, CH2: solar cell on display; flash a light at the camera, measure time between Ch1 and Ch2 spikes.
I don't think the result is quantitative in either case. So why bother with the opamps?
Offline FenTiger
Re: Optical probe for oscilloscope
« Reply #1 on: May 05, 2020, 09:21:47 pm »
Impedance matching? The photodiode sees a roughly zero Ω load due to the virtual ground created by IC3A, while IC3B is configured to drive a 50Ω cable.
Dave92F1
  • Guest
« Reply #2 on: May 05, 2020, 10:58:15 pm »
Impedance matching?
Maybe. Would that improve the frequency response?
I mean, why bother impedance matching? A solar cell (or I presume a photodiode) seems to drive an oscilloscope directly just fine.
Offline FenTiger
« Reply #3 on: May 06, 2020, 01:35:09 am »
I don't know. I'm just guessing, and hoping somebody will tell me why I'm wrong. ;)
Offline JohnPi
« Reply #4 on: May 06, 2020, 04:23:44 am »
Bandwidth.
A scope may have ~ 20 pF or input capacitance in parallel with 1 MΩ -- giving a time constant of about 20p*1M = 20 us. The photodiode (which has additional capacitance, further reducing the BW) generates a current and this takes some time to charge the 20 pF capacitance. When the light turns off, it takes some time for the 1 MΩ to discharge the capacitance. The final voltage is the photocurrent * 1 MΩ, or the VF of the photodiode itself (about 0.6 V). An opamp appears to short the photodiode current to the virtual ground -- thus that current doesn't have to charge any capacitance -- the opamp does the work of driving the output and also the virtual ground through the feedback resistor, giving an output voltage of Iphotodiode* Rfeedback.
You can see this yourself -- touch and remove a scope probe to a battery or power supply -- you will see a fast rising edge when you make contact, but an exponential decay when removed (it may be quite noisy when you do this manually, but you will be able to get a few clean traces)
Online tggzzz
« Reply #5 on: May 06, 2020, 07:00:58 am »
Search terms that will help: photovoltaic mode, photoconductive mode, PIN photodiode, transimpedance amp.
Which type of design is most appropriate depends on objectives and constraints.
Offline tanveerriaz
  • Country: pk
« Reply #6 on: May 06, 2020, 06:46:57 pm »
response time of solar cell and photodiodes are difference .
