you can buy 5k quantity and put it on ebay. For a KH it might be worth the money to get it right
or just get long lead time one and wait too
I get irked and sometimes buy components in large quantity to fix things as original if their cheap enough instead of building wiccan resistor sculptures. but those resistor look expensive @ 70 cents each too much. if it was 7 cents at quantity for 250$ it might be worth buying
I often wonder if you can micro tig weld or braze SMT resistors into TH form and make a good resistor that way too.
The most interesting process for metrology would be electroplate welding, that is... you form copper around parts until they are 'welded' together via slow electrochemistry. it might be a way to attach a lead to a resistor without heating it too much and have it reliable.
they are causing so many problems because of component cost misering, it must be possible to add manufacturing quality leads to whatever you want. I think EP-welding might be the bet if someone can figure out how exactly. I think you just need a good fixture
I imagine a flow cell, perhaps out of wax built around a fixtured component and lead with low current and filtering. that might make a precise enough joint. I think you just set them up on a taper like welding and fill it up then sand it down
