I ran the calibration routine on my newly aquired E3631A two days ago and I am still wondering about one detail:
The service manual requests the unit to be in CV mode during voltage calibration, which obvioulsy makes sense as otherwise, the unit would not be able to freely adjust it's voltage output to the value intended for each respective calibration step. As there is nothing attached to the PSU besides the DMM for calibration, CV mode is engaged naturally.
However, for the current calibration steep, the service manual does neither explicitly request the PSU to be in CC mode, nor does it forbid that. How can the PSU control its current output if not via CC mode?
I originally set my electronic load to 1.2Ohm for the 6V output and 25Ohm for the 25V outputs to replace the shunts that are specified in the service manual with respect to the maximum power capabilities (6V/5A and 25V/1A each). However, the regulation in the electronic load and in the PSU kept fighting against each other, leading to jumping values. To me, the only sensible solution was to drop the load into CV mode and choose a target voltage slightly below what would engage the CC control on the PSU in a stable manner so I could feed the PSU a stable reference value to process the calibration on.
The calibration routine passed and follow-up tests confirmed that the PSU is now in line with my DMM at various voltages and current. Questios remain: did I miss something or why is the CC mode not a requirement mentioned in the manual? And if so, couldn't the calibration routine be done with just a simple short instead of the electronic load? In the end, it seems it was only about the current set by the CC limiter.
Thanks for any explanations,
Christian
