Thanks for your reply Conrad.
One of the reasons I salvaged the wire is to analyze its elemental content , physical dimensions, hardness, resistance per unit of measurement etc. That's a big part of my metrology hobby. My elemental analysis is limited to those heavier than scandium at the moment, but trying o lower that bar o a shoestring budget takes time.
Yes it was soldered before but how was it prepped? Maybe a acid etch? Special flux?
My efforts with 700 F temperatures ad ordinary electronic flux didn't work well at all.
By the way, the heater........errrr.......I mean resistance wires are soldered to the main wires with soft solder, but at the other ed where those main wires attach to the massive copper switch contacts, the solder is very much harder variety. Will eventually check that solder for possible silver content.
The resistance per foot was rather high , only measured a less than 1/2" segment - it was 3 Ohms already.
