Author Topic: EZGBIP Program help please  (Read 1826 times)
Offline jeremynicholsTopic starter
« on: February 08, 2020, 05:25:29 am »
Some time ago, Guido posted a reply to an August 20, 2018 request, " Would some kind soul post a sample EZGPIB program." The OP was trying to read data from his HP-3456A DVM.  I am unable to get Guido's program (below) to work. It compiles error-free but no data is retrieved from my 3456A. The only difference I can see is that the OP was using a Prologix GPIB-USB adapter and mine is GPIB-Ethernet. GPIB Configurator confirms that my 3456A can talk to the Prologix adapter and via that and the network, to my PC running EZGBIP (version 20121217). The only change I made to Guido's program was to change the GPIB address to 22 as used by my 3456A. Since I have no programming experience newer than Applesoft BASIC, I would appreciate some advice as to what I might be doing wrong.
Here is Guido's program:
  Const Device  = 22;                                               // GPIB address
         Timeout = 5;                                               // timeout
Var   Answer:string;
begin;                                                              // main
  EZGPIB_BusEnableEoi;                                              // enable EOI
  EZGPIB_BusSetEos(0);                                              // Append CR+LF to instrument commands; MODE 4
  EZGPIB_ScreenClear;
  repeat
    EZGPIB_BusWaitForData(Device,Answer,Timeout);                   // Wait for data
    EZGPIB_ScreenWriteLn(Answer);                                   // Write data to screen
  until ezgpib_kbdKeyPressed;
  end.
Offline babysitter
  • pushing silicon at work
Re: EZGBIP Program help please
« Reply #1 on: February 09, 2020, 04:02:56 pm »
In the area between sourcecode and console you get debug messages. What happens there? Also, there is a "debug window" you can summon which should tell you about interfaces found - whats going on there? I have only the USB interface, but the website says GPIB-LAN is supported too.
I'm not a feature, I'm a bug! ARC DG3HDA
« Reply #2 on: February 10, 2020, 06:48:18 pm »
There is no response in either window when I attempt to run the program. I'll attempt to find the "debug window" when my 3456A becomes available (it's tied up in another project).
Offline babysitter
« Reply #3 on: February 10, 2020, 07:42:36 pm »
The debug windows should tell you which Interface is found, even without further GPIB Bus members.
Offline borghese
  • Country: si
« Reply #4 on: February 10, 2020, 07:48:17 pm »
Hello
If your adapter is configured as a controller and the HP3456 is not in 'talk only' you must tell HP what to do.
Try adding this line:
repeat
    EZGPIB_BusWriteData(Device,'F1T1');                               // DCV and Trigger
« Last Edit: February 10, 2020, 07:50:15 pm by borghese »
Cheers
Borghese
Offline RandallMcRee
« Reply #6 on: February 14, 2020, 02:32:37 am »
I did have the EZGPIB program working recently and then it stopped working.
The problem?
I needed to run EZGPIBConfigurator from John Miles, see
http://www.ke5fx.com/gpib/readme.htm
to set Prologix's usb port, which apparently changed.
Hope this helps,
Randall
