That AN by Bob Pease is one of the very best analog op amp ANs ever written!! All the old analog designers back then would just "brush" any non-linearity under the table of open-loop gain, the younger ones would run to Berkley SPICE for another "wrong" answer. Bob's AN showed you just can't do that in either case!!
Bob's use of the DUT itself as it's own high gain preamp is just brilliant, typical of Bob Pease and Jim Williams circuit design creativity
I vividly remember Solomon's IEEE paper and how it showed the 741 gain reverseing due to thermal feedback, this meant the + and - inputs reversed under thermal loads, also shown in Bob's AN
Back in early 90s we had developed primitive thermal models for bipolars that would run in SPICE, much later VBIC, MEXTRAM and HICUM bipolar models incorporated thermal effects, the later ones included dual thermal time constants.
Best,
