hello all,
contrary to popular belief, EMC work is NOT voodoo or black magic, but the correct application of well known engineering principles. I have been doing this for the last quarter of a century, successfully bringing many millions of € worth of devices through CE and FCC testing and certification.
First principle: know your enemy. In this case: which disturbance frequency? Many of the older equipment we collect and use was designed in a time, when AM and FM radio and CB radio was the main threat. Often it was simply assumed, that precision lab equipment would only operate in temperature and humidity controlled, well shielded rooms. Using a calibrator of 70s or 80s vintage in a home environment exposes it to strong fields in the 900, 1800, 2400MHZ and 5150 to 5700MHz range. Was it designed to cope with that? Maybe it has filtering against AM and FM radio, but not much more - mobile phones and WLAN were not in every household back then.
So what can we do? Throwing any ferrite we can find in our junk box at the problem does not help, as Andreas found out. Using the wrong ferrite can make it even worse, no joke! It must be the RIGHT ferrite material at the RIGHT place. How do we find out which one?
For a first look at the problem, it is useful to look what radio amateurs do in such a situation. I found a useful introduction to RFI problems and solutions:
http://audiosystemsgroup.com/PAARA-RFI-2011.pdfThe guy who wrote it, Jim Brown K9YC, was the EMC expert of the AES and has done extensive tests to assess the susceptibility of audio equipment to RFI.
Another great resource is the Book "Electromagnetic Compatibility Engineering" by Henry W. Ott. I have it on my lab bench during EMC work. Saved my ass on some occasions. It should be called "The Art Of EMC", really...
And now some hints: if you want to solve EMC problems, you should be able to measure/see whats going on - preferably up to 1GHz. I do quick checks with a handheld transceiver (Yaesu FT1XD) in scan mode. It also helps if you can listen to the disturbance - is it white noise, some kind of buzz or does it sound like radio or a data modulation (you all remember the sound of a fax or modem, do you?). Another low-cost option is the new TinySA. If it works as well as my NanoVNA, is a must for hobbyist EMC work.
For a broadband suppression choke, there is still the good old six-hole ferrite bead:
https://www.we-online.de/katalog/datasheet/7427503.pdfAs you can see, useful up to at least 1GHz. I keep a bag of them handy in the lab. Due to their construction, they do not show the parallel resonance of the classical choke. They are also very useful in filtering power supplies and brushed motors.
I would also recommend to have a look at the application notes on the Würth homepage:
https://www.we-online.de/katalog/de/pbs/emc_components (switch to "english" left of the shopping cart symbol).
Hope that helps.
Greetings,
Rainer
