Author Topic: NK4-1 low current and high resistance calibrator (made in Belarus)  (Read 2754 times)
Offline bsw_mTopic starter
  • Country: by
NK4-1 has arrived.
This reference calibrator designed in MNIPI and go to production in 1989 year. Later this instrument has certified as low current & high resistance standard.
My unit produced at end 1996year and have serial number 14.
Minimal metrologically significant current that this calibrator can generate is 1E-17A with resolution up to 1Е-20A
First power on attempt fail. Computer in this device has not work. But after cleaning sockets, computer started.
Photo and first test.
« Last Edit: July 15, 2021, 05:51:56 pm by bsw_m »
The following users thanked this post: Vgkid, HighVoltage, doktor pyta, shodan@micron, serg-el, MegaVolt
Online TimFox
Re: NK4-1 low current and high resistance calibrator (made in Belarus)
« Reply #1 on: August 11, 2020, 03:46:29 pm »
Very nice device, with that interesting proprietary low-leakage connector.  Is there a standard cable to connect with the Keysight B9285A triax input?
(For my less-sensitive requirements, I rely on a Keithley K261 "picoampere current source" to work with my Keithley 610C analog and 616 digital electrometers.  It is merely a Kelvin-Varley divider driving a set of the usual glass-encased Victoreen carbon resistors mounted on a rotary switch.  The most sensitive range is 0 to 9.99 V through a 1 x 1012 ohm resistor.)
  • Country: by
« Reply #2 on: August 14, 2020, 10:06:48 am »
Thanks!
This device doesn't have standard cable for connect to B2985A and similar. Need to DIY.
For currents >=1E-9A this device use network of precision microwire resistors and DAC.
For currents <1E-9A this device use capacitors and DAC that generate ramp voltage.
The use of differentiating capacitors to generate ultra-low currents in this calibrator has solved 2 problems at once.
1. Lack of stable ultra-high resistance resistors suitable for the high precise generation of such currents.
2. Get rid the thermal noise of the resistors.
The amplifier of V7-45 for the same reasons also using integrating capacitor in their feedback. - Full eliminate current noise from resistors. And more precise measurement, due the capacitor is more stable than ultra high resistance resistors (time and temperature).
Photos: output connector with sapphire insulator on differentiator №2. This differentiator used to generate output currents from 1E-14A to 1E-16A. And connector with amber insulator on one of kit's cable.
« Last Edit: August 14, 2020, 02:07:37 pm by bsw_m »
The following users thanked this post: shodan@micron
  • Country: by
« Reply #3 on: August 14, 2020, 10:34:50 am »
Sweet couple: NK4-1 and V7-45. Calibrator that can generate 1E-17A and electrometr that can measure this current.
On photo there devices are not acting.
« Last Edit: August 14, 2020, 12:42:43 pm by bsw_m »
  • Country: by
The following users thanked this post: doktor pyta, MegaVolt
  • Country: by
« Reply #5 on: October 14, 2020, 03:05:34 pm »
For those who can read in Russian. An article on the creation of a standard for ultra-low currents
The following users thanked this post: Mickle T., doktor pyta, MegaVolt
  • Country: by
« Reply #6 on: October 16, 2020, 06:04:14 am »
I scanned the first book of documentation for the NK4-1 device. Perhaps someone will come in handy.
https://drive.google.com/drive/folders/1D9E9QGc1qtWnUpHSRtgMRAiQxbgFVZO7?usp=sharing
The following users thanked this post: Vgkid, doktor pyta, serg-el, MegaVolt
