> I'm making a PCB design for HP10811. Should be handy
> for offset or reference oscillator. I'll post here when it's done.
I have made one for 10811A, Morion MV89, MTI-260 and
some less known, up to 100 MHz. It has a coolrunner CPLD
to generate a local 1pps. There is also a post amplifier
to increase power output to ~20dBm, with the option
to use it as a push-pull frequency doubler, with 2 crystal
notches against sub/harmonics. 10 MHz Morions have
an internal doubler and can use that.
There is a 2FF phase comparator in the $3 CPLD and the
low pass filter on the board to lock the oven as a clean-up
oscillator to an incoming reference frequency.
The hardware could also lock to an incoming 1pps, for
GPS etc. This has not yet been completely implemented in
the CPLD. Frequency locking works.
Vtune direction and some common frequencies are strapping
options and can be changed without touching the VHDL
of the CPLD.
Everything is optional. Think of it as a toolbox.
Someone in the US had boards produced locally from the
Gerber set, just for mechanical mounting.
Cheers, Gerhard
