Is there an inherent advantage in using a differential IF configuration? I figured my parts bin doesn't contain any Tesla stuff but instead of the MA3000, any FDA could be used, like, LTC6362 or THS4131?
The THS4131 could be used with a single 5V supply rail, at the cost of increased THD (haha!).
MA3000 is clone of RCA CA3000. But there are still companys around that have stock of MA3000. In principle any FDA could be used.
The FDA should amplify a slow changing voltage (1-10Hz) -> low input offset voltage, input offset voltage thermal drift and voltage noise
It should attenuate residual high frequency signal coming through filter -> high CMRR at Frequency in 10Mhz range.
Differential signal path has the benefit of not beeing referenced to ground (currents through the groundplane can't inject noise).
When using a single ended topology you have to make sure all components (opamp inputs, filter components) see the "same" ground -
for MHz you want a groundplane, for Hz you want star ground (generally speaking). Here you have both so it might be complicated.
I have opted to just reference all the circuit to the groundplane, in a single ended configuration this would not be optimal.
In my circuit the only (DC) connection of the IF signal to ground is at one point, and not directly as something to compare against as well (opamp/comperator input).
Also, if noise couples into the differential path from the outside (hopefully evenly) it is rejected by the opamp (to the best (CMRR) of it's ability (inside it's bandwith))
