branadic wants me to spill the beans
Some time after starting the CM-measurements on the Potcore-pcb-design i noticed same flaws in the measurement, therefore i`ll correct those and do the measurements again. For this whole project i'll open another thread then.
Corrections for the next measurements:
-take scope-screenshots with different bandwidths for every configuration, as the perceived noise differs between scope and SA (like done in
https://x.artofelectronics.net/wp-content/uploads/2019/11/9xp14_low-noise_isolated-pwr.pdf -measure every configuration with SA, scope (in 20MHz and Full BW) and HP 3403C RMS meter
-using a Hammond case to shield the measurement completely while using BNC-feedthroughs (no simple BNC-jacks with attached coax-cable wy pigtails which worsens BNC-shielding) as measuring the pcb on the table introduces external noise in the more sensitive ranges
DM-noise isnt measured right now, since i would first need to repair my LNA for that. I will do it later though.
LT3439 is now used instead of the LT1533 since it can handle the 12Vin (roughly, no exact requirement) 12Vout @ 200mA spec, without overheating when the slewrate is increased to 1µs or more.
I kept the LT1533 in the potcore and Pickering design though since its still usable when drawing less output power.
I attached the measurement results so far (missing scope/RMS meter measurements), schematic for the potcore design and the gerber files for the three test pcbs which use different transformers: P26/P30 potcore transformer, Pickering/Teflon transformer and Triaxial/Coaxial transformer (like in the DMM7510).
The potcore-design works and is tested, while i havent yet received the Pickering and Coaxtransformer-pcbs and therefore cant guarantee anything here.
Maybe someone wants to join the project and replicate my measurements or better yet: one up me and produce even lower CM-noise results by using better techniques
