Author Topic: DMM Volts/Ohm Calibration Club - anyone interested?  (Read 85756 times)
Offline 0.01C
  • Country: hk
Re: DMM Volts/Ohm Calibration Club - anyone interested?
« Reply #225 on: June 16, 2017, 02:26:59 am »
Hi @0.01C
Where did you buy the pure copper spade lugs?
enut11
I bought from taobao.com , ¥16 100pcs
If you want ,I can send you some .
« Last Edit: June 16, 2017, 03:07:38 am by 0.01C »
0.01℃
The following users thanked this post: julianhigginson
Offline enut11Topic starter
  • Love building/modifying/restoring test equipment
« Reply #226 on: June 16, 2017, 02:48:41 am »
Hi @0.01C
I went to taobao.com but could not see how to change the web-page to English. Can you sell me some copper lugs or buy some on my behalf? PM me if interested.
enut11
an electronics nut from wayback...
Offline 0.01C
  • Country: hk
« Reply #227 on: June 16, 2017, 03:15:52 am »
Hi @0.01C
enut11
Sure ,I can send you some for free ,pm me
0.01℃
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #228 on: June 16, 2017, 04:03:09 am »
I'd like few too. :) Checking with some factory to make copper banana jacks too, still in progress to get quotation.
Offline 0.01C
  • Country: hk
« Reply #229 on: June 16, 2017, 05:00:03 am »
no problem :), pm me,
I think banana jacks is not good for low thermal .
taobao diy binding post @$3.5 :popcorn:
0.01℃
Offline Vgkid
« Reply #230 on: June 16, 2017, 05:40:31 am »
Can you give us some links, please.
Thanks.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #231 on: June 16, 2017, 05:53:52 am »
I agree, banana is a PITA to use for high precision stuff, but I'm not ready yet to modify my Keithley 2002's for binding posts :)
Offline SvanGool
« Reply #232 on: June 16, 2017, 07:24:13 am »
I would also be very interested in copper lugs, binding posts and banana plugs. FYI I now submit tinned copper items to DIY electrolysis and that works, for certain brands (some use another plating process) but it is a tedious process.
# Don't hurry, the past will wait. #
Offline Ash
« Reply #233 on: June 16, 2017, 07:35:25 am »
Those look good. I'd be keen to purchase some of those and the copper lugs as well. I've several projects coming up that I'd use the copper binding posts on and they look perfect.
If you could provide links that would be cool! Or if you wanted to run a group buy I'd be happy to be involved.
Thanks heaps.
Ash.
Offline VK5RC
« Reply #234 on: June 16, 2017, 07:48:23 am »
I have a similar opinion re a 34461.
A while ago I made a pair of lug to banana adapters (bodge city! - soldered)  and did a run with an ltz1000, with either the adapters in or out of the circuit, (main lead was Pomona low emf banana pair lead)
No difference detected with about 500 measurements in each run but constant temperature .
PS Aus Cal guys - the adapters are coming around with the ltz1000.
Robert
Edit   corrected model number
« Last Edit: June 17, 2017, 12:26:33 am by VK5RC »
The following users thanked this post: enut11
Offline 0.01C
  • Country: hk
« Reply #235 on: June 16, 2017, 08:57:52 am »
Thanks heaps.
Ash.
here  https://world.taobao.com/item/40823926055.htm?fromSite=main&_u=g1paopr9dbf
0.01℃
The following users thanked this post: Vgkid, Ash, julianhigginson
Offline Ash
« Reply #236 on: June 16, 2017, 10:06:08 am »
Ok, first time I've used Taobao and had to rely on Google Translate.  :-+
Hoping it works out!  :-//
Thanks for the link!
Ash.
Offline 0.01C
  • Country: hk
« Reply #237 on: June 16, 2017, 10:50:41 am »
Ash.
I just contact the binding posts seller , his email is qinchang001@sohu.com   ,if you have question ,you can contact him.
ps : I don't know the seller and bought from him only once.
0.01℃
The following users thanked this post: Ash
Offline SvanGool
« Reply #238 on: June 16, 2017, 12:20:51 pm »
I looked at Tao Bao to purchase 10 pieces but I am getting 240 Yuan shipping cost to Europe, which is about 32 Euro.
Offline 0.01C
  • Country: hk
« Reply #239 on: June 16, 2017, 01:08:48 pm »
10pcs is about 100g ,ship from HK POST to Italy is about HKD40.
« Last Edit: June 16, 2017, 01:27:30 pm by 0.01C »
0.01℃
Offline SvanGool
« Reply #240 on: June 16, 2017, 01:33:47 pm »
That would be indeed much better shipping cost (app. 4.57 Euro), now we need to convince the seller/Taobao  :)
Taobao recommends to contact the seller about the shipping cost, I did, no reply yet.
(Meanwhile we are polluting this thread from message msg1234742 on, maybe a moderator can move this to a new "Low thermal-EMF materials" thread)
« Last Edit: June 17, 2017, 09:24:36 am by SvanGool »
Offline VK5RC
« Reply #241 on: July 10, 2017, 09:27:25 am »
With thanks to TiN and I believe SvanGool for putting design up on OshPark, and Lou et al for the Aus Cal Club  :-+
A set of 6+ LTZ references being slowly built- aim is long term  - kept ON  - in a controlled temp cabinet, measured every 3 months or so - watch their drift (and that of my 3458 and 34461).
Difficult part will be getting lab at a constant temp without too much interference from heating-cooling system- I don't have a cellar - but tempted to dig a big pit!
I will probably heat / cool lab for 48hrs prior to measure time - then switch off.  I have also seen a little interference from the computer +/- PSU  / GPIB interface. Lots of known (and avoidable) interference from LED lights and other SWPSUs.
Most (5)  will be with TE UPS50 resistors, closest I can easily get to 13k is 13.3k (paralleled 20k and 40k), 70k (20k+50k), I have one set of Mr Pettis' left.
Four will be with LT1006 and 100nF across 1k and 120R, but two LT2057s
Four  will be with LTZ1000As but a generous Aussie gave an LTZ1000C and I have one 'C' of my own.
It won't be a quick result project!
Robert
VK5RC
Offline bitseeker
« Reply #242 on: July 10, 2017, 10:00:05 pm »
A cellar would be a nice thing to have for relatively constant temp. The humidity might not be ideal, depending on where you're located. Underground/cave lab in the middle of the desert. ;D
Offline GFWD1D
« Reply #243 on: August 09, 2017, 11:41:52 am »
Hi I'm new to this forum and would like to know more about your building of V refs.
I'm also interested in the calibration forum that has been set up here in ADL or Aust.
« Reply #244 on: August 09, 2017, 08:11:11 pm »
Hi GFWD1D
Please tell me a bit about yourself wrt electronics, professional or hobbyist?
Also what type of equipment do you own and what State/town do you live in.
What do want to achieve wrt Vrefs?
Please send your reply via Personal Messages.
Regards
enut11
« Last Edit: August 09, 2017, 08:13:56 pm by enut11 »
« Reply #245 on: August 11, 2017, 11:30:50 pm »
Hi GFWD1D. A good way to start out in Metrology with Vrefs is to build an LM399 based reference. Parts are easy to get and not expensive. PCBs are available from one of our Aussie Cal Club members.
Use a plastic or metal box (better shielding) and download the LM399 spec sheet. This circuit is based on the 'portable calibrator' from the spec sheet. You can power it from a regulated 15v supply (not switch-mode, too noisy) or from a battery (lower noise). Circuit draws about 25mA. The 3 output terminals provide Vz and 10v.
enut11
Offline VK5RC
« Reply #246 on: September 30, 2017, 12:15:45 pm »
Hi Aus Cal Guys et al.
Sometimes out of a stuff up comes some good. My LTZ references (almost all Kx - Thanks again Ilya) have been sitting in a shelf as part of a longer term experiment- mostly happy - I moved some other test gear a week or so ago and didn't noticed the pile of stuff had moved and pulled out the DC connectors!
I thought it would be good to put it all in a steel enclosure I had spare. It started to grow a bit as a project . I have a linear mains to 18V DC supply which can been seen outside the box in the photo below - labelled PSU1.
The DC is transferred in some shielded twin cable - directly into a small common mode filter box "Filter". Consists of about 2x14 turns (counter-wound) on a ferrite core and a small 100nF cap between the DC rails. The shield is connected to the box - not mains earth. 18V is distributed to secondary low noise linear PSUs, based upon TPS7A4700 - down to 15V for the KX labelled PSU2.
Today quite a bit of time was spent grinding off paint and checking continuity between the panels, rails etc. Common tie point to the shields.
Inside references were well fixed (my favourite 'bodge' attachment method) using double sided sticky tape and zip ties.
Previously I have had some interference from SMPSUs in my DC measurements esp my LED downlights - often in the order of 10-30uV! Today following the 'boxing' it is down to around 1-2uV. :-+
Edit ; grammar.
« Last Edit: September 30, 2017, 12:17:35 pm by VK5RC »
« Reply #247 on: November 17, 2017, 09:32:10 am »
Bump  :)
Collected most of the bits I need. Ali box for the Vishay .005% arriving next week.
Plan is two socketed Max 6350 CPA references powered by 3S LiPo's in the small Ali enclosures with charge and cut out boards (shielded from the reference as well as space allows)
Vishays 2 x 10k, 1x 5k, 2x500R and a 100R mounted as 4W independent resistors so they can be used as a precision divider set. Allows 1-10V in 1Vsteps and 0-5 at .5V or 1-20mA precision currents plus others which suits the accurate temperature logging projects I am working on. Considering adding an additional 2 resistors to this lot yet to generate a few more steps.
Seemingly very accurate Agilent 34401A (2 years out of Cal from a clean room environment)
Might mount the lot into a larger temp stable enclosure at some stage but 3 units suits my limited bench space. :)
So consider me interested in a swap of some sort in the New Year if it comes up again.
« Reply #248 on: November 18, 2017, 01:01:13 am »
Hi @beanflying
Let us know when you are ready to compare your Ref measurements with ours. We have several DMMs with 6-8 digits.
enut11
PS
I am also into R/C flying. Where do you live?
« Reply #249 on: November 18, 2017, 01:08:47 am »
SW Victoria in Koroit / Port Fairy area.
Breadboarded one of the Max's this morning. Horrible thing 4.99997V I blame the Temperature it's only 23 degrees :-DD
On for 30 minutes now. Top of the chip is 27 degrees and 5.00001V 8)
« Last Edit: November 18, 2017, 01:13:04 am by beanflying »
