I've just noticed that there is an Aussie Cal club. (I've only really been active on the forum for the last month I guess).
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I'd love to get involved as well. @enut11, Do I just PM you my details?
I've got a Keithley 2015, and will have 2 Keithley 196s soon (all 6.5 digit). Nothing in cal, but all should have good well aged references to compare against.
I do also have an EDC 521 voltage calibrator that I fixed, but I don't trust that it is anywhere near in cal, but it would be a good baseline to compare against I guess. I was planning on constantly tracking it against all the Keithleys to get some relative drift confidence.
I also have a matrix switch coming and I was planning to design and build some "simple" zener references (a little ways off yet) and use this gear the track them all against each other. I use Prologix Ethernet GPIB interface and can write code to drive it all.
If there is anyone in the Brisbane area with access to a calibrated 6.5+ meter, I'd like to adjust my EDC voltage standard if that would be possible??
Thanks,
Ash.
