my company has a Fluke 5500A connected to a Windows 10 machine with a USB GPIB-HS adapter. We are running Fluke Met/Track 8.3.2. When I try to run ANY procedure, the calibrator will REBOOT and the runtime will error out. In NIMax, I can SEE and QUERY the calibrator with no problem. When I run NI I/O trace and watch the procedure load, all the I/O trace shows is NOADDR.
