Author Topic: DIY ceramic PCBs from applied science  (Read 2832 times)
Offline golf32Topic starter
« on: September 26, 2021, 05:53:43 am »
Just figured I'd link Applied Science's most recent video about laser cutting ceramics. One application he goes into depth with is ceramic PCBs. Obvious implication for high precision circuitry. Thoughts?
The following users thanked this post: SeanB, TiN, chuckb, ramon, eplpwr, KT88, Just_another_Dave
Offline KT88
Re: DIY ceramic PCBs from applied science
« Reply #1 on: September 26, 2021, 12:30:16 pm »
Hmmm - I alreaady see myself building a standard capacitor with structures on fused silica...
Offline ahbushnell
« Reply #2 on: September 29, 2021, 11:50:27 pm »
This guy is great!   :-+
Andy
« Reply #3 on: September 30, 2021, 03:40:51 am »
I wonder how hard it would be to get carbon to stick. DIY precision resistors anyone?
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #4 on: September 30, 2021, 03:47:15 am »
Precision resistors are not made out of carbon :)
« Reply #5 on: September 30, 2021, 07:46:11 am »
Right, film/foil. He's not too far off from film resistors, he has a pretty cool deposition setup.
Offline KT88
« Reply #6 on: September 30, 2021, 09:32:17 am »
How about tantalum nitride?
« Last Edit: September 30, 2021, 10:52:54 pm by KT88 »
Offline chickenHeadKnob
« Reply #7 on: September 30, 2021, 10:33:08 pm »
The home gamer is far better off attempting wirewound resisters. Much simpler process wise, but still has complications with stress relief and termination.
The most stable Vishay metal films have two different metals with countervailing TCR's deposited side by side on a special substrate, good luck duplicating or beating that at home.
« Reply #8 on: October 01, 2021, 12:23:03 am »
I don't think we're far off from DIY film resistors. Applied Science has everything in his shop to make some. PVD, maskless steppers/etching, and now ceramic PCBs seem to be within the grasp of the hobbyist. It'd take a lot (understatement) of experimentation to get Vishay foil level results, but if you have your processes down I'm sure one could make some nice resistors.
« Last Edit: October 01, 2021, 12:25:56 am by golf32 »
Offline ramon
  • Country: tw
« Reply #9 on: October 01, 2021, 01:37:21 am »
That guy is amazing. It also has a video about ALD
"Atomic-Layer-Deposited Alumina (Al2O3) Coating on Thin-Film Cryoresistors"
DOI: 10.1109/TIM.2008.2006964
Abstract:
Metal-alloy (Ni-Cr-Cu-Al-Ge) thin-film resistors were coated with alumina (Al2O3) using the atomic layer deposition (ALD) technique. The electrical properties of the thin-film resistors were studied in the temperature range of 4.2-300 K. It was experimentally demonstrated that the protective dielectric alumina coating improves the long-term stability and repeatability of high-value, thin-film resistors (100-500 kOmega). The drift rate of the resistance due to the native oxidation at room temperature was reduced from -2.45 times 10^-6 h^-1 for a nonaged uncoated resistor to 0.03 times 10^-6 h^-1 for an alumina-coated resistor. It was shown that the additional 15-nm-thick alumina coating does not significantly change the thermoelectrical properties of the metal-alloy, thin-film resistors.
Offline David Hess
  • DavidH
« Reply #10 on: October 02, 2021, 07:28:00 pm »
Tektronix had their own ceramics lab firing silver onto ceramic for their terminal strips starting in 1952.  I wonder what the composition of their silver paste was.
https://w140.com/tekwiki/wiki/Ceramic_Strips
Thick film resistors are screen printed and then fired but they are not usually carbon.  Thin film carbon resistors are deposited somehow.
