BTW gotta love these nice low noise DSOs, we just need more resolution now, (read creating excuses justifications for a 12 bitter) ![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
Mine's a 10 bitter! It was the same price as the tek scopes in my range but had a lot of cool extra features.
So inspired by the JFET current limiter idea, but too impatient to wait for JFET's to arrive, I managed to come up with a MOSFET input protection circuit that appears to be working really well!
Here is the basic mod: A series n-ch and p-ch MOSFET pair, each biased to be on when the input signal is near 0V.
![](https://i.imgur.com/KQdcNQI.png)
I was able to rework it onto the board fairly easily:
![](https://i.imgur.com/0WACtqN.jpg)
![](https://i.imgur.com/CZtdg08.jpg)
I did some quick functional testing by feeding the input of the amp board with a 19Vp-p sinewave from a signal generator. I measured the voltage just after the MOSFET pair, and it was clamped well below the ±4.5V supply rails, which is perfect! There is actually no current flowing besides opamp bias currents, so there is no risk of blowing up the opamps internal protection diodes.
![](https://i.imgur.com/PYAfmQC.png)
I then turned off 9V to the amp board, and the voltage simply goes to zero, with no increased current draw.
![](https://i.imgur.com/HDsB3tD.png)
So with the protection features confirmed, I made sure that it is still accurately conducting signals that should be in range. I fed in a 100µVp-p test signal, and the output looked perfect.
![](https://i.imgur.com/QjzNeLH.png)
Noise performance with a shorted input is great! about 140 - 160nVp-p, or 17.92nV RMS (Cfg#13). This is by far the best input protection, and best noise performance of any protected variant. 17.92nV RMS corresponds to 10nV√Hz per opamp with a 11.3Hz bandwidth (10Hz with a 4th order LP filter), and the datasheet is 9nV√Hz, so I'd say I'm pretty close to optimized for these opamps.
![](https://i.imgur.com/EMsrq6m.png)
I actually have a couple LT1037's on order, so I'll have to test those. It should be significantly lower noise, even just using one, but the current consumption might go up a bit. I think with a re-design I could use cheap and low-power 5V chopper amps to do all the filtering. Any half decent chopper won't have 1/f noise, and broadband noise won't be too important after the 200x gain stage.
