Author Topic: DE-5000 LCR component test fixture or stuff into blades?  (Read 1249 times)
Online coppercone2Topic starter
« on: August 27, 2022, 02:17:57 am »
So on the De-5000 you can stuff a leaded components into the sense blades if you want. Is this safe, or do you need some kind of adapter to not damage the contacts to use it as a component tester? It seems perfect but I don't know if its a good idea.
Offline macboy
Re: DE-5000 LCR component test fixture or stuff into blades?
« Reply #1 on: August 27, 2022, 02:39:09 am »
That's exactly what those sockets are there for. Make sure to do the open/short calibration.
« Reply #2 on: August 27, 2022, 03:00:15 am »
Ok I thought it was only for the adapters, I was not sure if those contacts are designed for leads
