On the soldermask it will be more or less fine. However on metal parts, especially non anodized heat-sinks, ir will be completely useless. Also IR thermometer is not very useful tool compared to the thermal imager. The biggest issue is that you never know if it shows you some bullshit, like reflected IR and similar. As laser aim usually is not precise at all, you won't be completely sure what part you actually are measuring.
