Interesting test gear for sure!
By coincidence, I bought my first Genrad item the other day - a 1454-AH resistance decade divider. After cleaning it up, a quick test drive showed that it still comfortably met its specification... not bad, after 50 - 60 years! Got to hand it to whoever made those resistors.
And stable! - that was the most surprising thing. Rock solid output. I guess when a divider is rated for 700 volts, it isn't even going to notice a modern 10V reference!
Seems to me that Genrad puts a new meaning to the term "over-engineered"... I have never seen rotary switches this big, coated with enough silver to pay off the national debt (just about)!
Is the GR 1559-B similarly over-engineered inside?
