Author Topic: Keysight DMM, difference between "Made in Singapore or Malaysia"  (Read 4726 times)
Offline HighVoltageTopic starter
Hello Voltnuts
As some of you might know, I have many Agilent / Keysight bench-top DMMs
One of my older 34401A was still built in the US and the serial number starts with a "US".
But all the others start a serial number with a MY for Malaysia.
This is true for my 34401A, 34450A, 34410A, 34411A, 34461A, 34470A and my 3458A as well.
But now I think I found a jewel under the Keysight DMMs !
I just bought a new 34401A, may be one of the last one made in 2016 ?
This one has a serial number that starts with a SG for Singapore.
"SD5300xxxx"
So, my question is, if any of you have come across a Keysight DMM, that was also made in Singapore and if there would be any difference to the DMMs made in Malaysia or if it does not make any difference?
This new 34401A was meant for a customer project, but I think I will keep it just as a special "collectors item"
« Last Edit: July 11, 2017, 11:42:10 am by HighVoltage »
Offline plesa
Re: Keysight DMM, difference between "Made in Signapore or Malaysia"
« Reply #1 on: July 08, 2017, 11:25:27 am »
There is no difference as far as I know. The reason was import tax.
« Reply #2 on: July 08, 2017, 11:44:39 am »
You mean to eliminate the import tax in to Singapore.
Hmm, that would make sense
Offline pe1oxp
  • ~ Life is too short for QRP ~
« Reply #3 on: July 09, 2017, 10:10:00 am »
I just wondered, why do the always place the Calibration Label on the display so you have to remove it to read everything on the display?
Why not on the backside...
Offline Electro Detective
« Reply #4 on: July 09, 2017, 10:23:29 am »
and orientate it horizontally to reduce the likelihood of a sprained neck   :-[
Offline pe1oxp
« Reply #5 on: July 09, 2017, 10:32:23 am »
In my case it is placed horizontally but over the Agilent logo and partially over the annunciators on the display
Offline coppice
« Reply #6 on: July 09, 2017, 10:33:46 am »
Because the guy tasked with scanning all the benches in the lab, to check the calibration stickers, doesn't want to take every instrument off the bench to check them. Its the same with any asset labels the user company adds to track their instruments. People want to check them quickly. The stickers either go on the front, or if the front is very crowded, around the front edge.
Offline Kleinstein
« Reply #7 on: July 09, 2017, 11:07:38 am »
With the crowded front of many modern large screen instruments they should have a reserved place for the stickers and property tags.
At least the did not put the cal sticker on the protective film of the display :-+.
Re: Keysight DMM, difference between "Made in Singapore or Malaysia"
« Reply #8 on: July 10, 2017, 10:43:46 am »
This was already my second new instrument I have received in the last few weeks from Keysight with the CAL label placed very ugly at the front and even covering the Keysight logo.
Here is my new 34470A picture from last month.
Interestingly, they also forgot to install the options.
But after sending it back, it was all fixed now nicely by Keysight.
Offline try
  • Metrology from waste
« Reply #9 on: July 10, 2017, 02:23:41 pm »
Oh my goodness,
HighVoltage has been awarded a tester license for Keysight crippleware.  ;)
Offline free_electron
    • SiliconValleyGarage
« Reply #10 on: July 10, 2017, 02:30:26 pm »
Government.
US government will not buy from malaysia. So they ship subassemblies from malaysia to singapore (just over the border. they are within spitting distance...). Finish them there at which point they can claim they were assembled in Singapore.
Problem solved.
The following users thanked this post: plesa, try, alm
Offline lukier
    • Homepage
« Reply #11 on: July 10, 2017, 04:10:30 pm »
It is over 700 km Penang (Keysight) to Singapore. Good spitting skills :D
(But seriously, the "government" explanation seems sensible)
« Reply #12 on: July 10, 2017, 04:54:09 pm »
Government.
Interesting.
So, essentially Keysight has an assembly place (not a real factory) in Singapore for all of their equipment sold to the US government?
Why would Keysight USA not import it to the US and then sell it to the government directly?
May be some government rules that we as engineers never understand.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #13 on: July 10, 2017, 05:14:01 pm »
Government.
Interesting.
The problem is the "Made in..." claim. It has to be minimally assembled at a given country to qualify. In the past I have seen reputable companies being heavily fined when violating this (not in the US, but still...).
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #14 on: July 10, 2017, 05:33:16 pm »
For my 34401A, the calib company placed it on the top (on the metal body) instead of the display. Then used a cal seal sticker on the back as standard, to prevent opening.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline plesa
« Reply #15 on: July 10, 2017, 07:29:54 pm »
Government.
Problem solved.
Thanks for info.
