Sounds like there is an issue inside.
You may 1st check, if this issue is HW related.
I would start by checking some vaules in the different range and values for value and stability.
You mentioned, your measured value is stable with some fluctuations on 7th digid.
Did you checked it with an oscillioscop, if there is some high frequency.
If it's ok, it may a lost of calibration data.
If it's not ok, next step could check the internal supply volatges (value, noise)
