Author Topic: Energy From a Supercapacitor  (Read 2223 times)
Offline Renato_power_darknessTopic starter
  • Country: br
« on: October 02, 2020, 01:58:54 pm »
Hi folks!!!
Is there a way to measure the max energy released from a capacitor ?..
For example. The max power released to a charge is the match impedance.. and how about the energy ??.
best regards ..
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Energy From a Supercapacitor
« Reply #1 on: October 02, 2020, 02:24:13 pm »
Yes. Discharge it at a fairly slow rate, so that leakage and conduction losses are balanced (somewhere between minutes and days).  Dissipate the energy into a perfectly insulated calorimeter (a well enough insulated one may not exist though), or measure V and I or P and integrate over time.
The capacitance can be known quite accurately over the same time scale, and the charge is linear with voltage, so E = C Vmax^2 / 2 also applies.
Power transfer theorem doesn't apply here: that would yield 50% efficiency. We can do better.
Seven Transistor Labs, LLC
The following users thanked this post: Renato_power_darkness
  • Country: br
« Reply #2 on: October 02, 2020, 02:57:19 pm »
Thank you so much, Tim.
There are lot of details in the test (fairly)  I'm gonna check this out.
Best regards!
Offline HighVoltage
« Reply #3 on: October 02, 2020, 02:57:55 pm »
I have done this in the past with a Keithley 2460 SMU, draining a Supercapacitor with a fixed current and use a script inside the instrument to calculate the total capacitance, energy and power. You can even graph it nicely with the 2460 SMU.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #4 on: October 03, 2020, 03:47:24 pm »
The energy is remarkably small, which is why energy storage as charge can't compete with things like batteries, save for short term high current loads.
Offline HighVoltage
« Reply #5 on: October 03, 2020, 04:26:22 pm »
I worked a lot with Maxwell 3000F Super Capacitors up to 2.7V
It looks really amazing, when charging them with 100A and the voltage rises so slow.
Almost unbelievable.
This 3000F capacitor has an energy storage of 10,935 Joules at 2.7V
Offline guenthert
« Reply #6 on: October 03, 2020, 05:32:09 pm »
     So I need only about 12 of those to absorb the kinetic energy of a (1300kg) car coming to a stand-still from 50km/h?  That's quite impressive.
Offline T3sl4co1l
« Reply #7 on: October 03, 2020, 06:09:31 pm »
Or to accelerate it to the same speed.  Better have a powerful inverter and motor.  >:D
« Reply #8 on: October 03, 2020, 06:20:06 pm »
OK, so that cap is 60 mm in diameter and 138 mm long, and it has the energy storage of an AA lithium ion battery. Admittedly it can charge and discharge very rapidly, but in terms of energy storage it's not in first place.
Offline T3sl4co1l
« Reply #9 on: October 03, 2020, 09:11:35 pm »
They don't find much use in EVs because once you have enough cells together, you have more than enough power capacity to do anything you want.  Same reason we're happy to use 1000s of uF of electrolytics instead of the bare minimum (100s uF?) ceramics in a switching supply: the power capacity is adequate and the price is right. :)
The following users thanked this post: I wanted a rude username
Offline HighVoltage
« Reply #10 on: October 04, 2020, 10:54:03 am »
One benefit for EVs would probably be the ultra low internal resistance of the super capacitors and therefore the fast charging from regeneration of breaking energy. So, like a buffer between the regeneration and the normal cells.
Tesla bought the Maxwell comapny, the manufacturer of these super capacitors.
Time will tell, how they will utilize this technology.
  • Country: br
« Reply #11 on: October 05, 2020, 03:12:35 pm »
Hi, mate!
I have a 2.7 V and 5F Maxwell. (I have another like 50 F)
What I'm trying to find is a fair way to measure the maximum energy deliverd, with lossses and realistc contents.
Did you get 10 joules from the manual ??
See yah
  • Country: br
« Reply #12 on: October 05, 2020, 03:15:50 pm »
I'm gonna try to get the discharve voltage curve under de charge, by an oscilocope and then, convert to power over time and then, integrate the area.
Thank you so much !!
Offline Ed inMelb
« Reply #13 on: October 21, 2020, 01:07:58 am »
UM, I make Super Caps and batteries, and I made a super cap as big as a shoe box that weighed a couple of kilo's.... INSTANT POWER!!
Online David Hess
  • DavidH
« Reply #14 on: October 21, 2020, 08:25:23 am »
If you know the capacitance, then available energy is simply 1/2cv^2, which means that when discharged to 1/2 of the starting voltage, 75% of the energy has been removed.
