Can you give a few pointers how to flash the upgrade? The file you linked to contains 5 files:-
DeviceCleanupCmd.exe
install mini GPS serial port drivers.bat
miniGPSclock.bin
miniGPSclock.exe
miniGPS-clock.inf
I have dowloaded Firmware Doctor & HID flash from your website. I can see how to update using HID & selecting the .bin file from your link, but before I do so, I was wondering what the other 4 files were for?
Unzip all the files into a folder. They will not work from inside the .zip
If you are on Windows 8 or earlier, run "install mini GPS serial port drivers.bat". This will clean registry and install .inf file
Windows 10 and 11 should not need drivers installation
Run miniGPSclock.exe and reflash the mini GPS clock to v1.20. Alternatively, you can use HIDflash for this as well.
You might need to OK Windows to use a driver without signature if it asks. (There isn't really a driver per se, just the .inf file to direct Windows to use its own one.)
Leo
