Author Topic: Samsung UCCM GPSDO reverse engineering  (Read 5724 times)
Offline ve7xenTopic starter
    • VE7XEN Blog
« on: January 12, 2021, 02:21:56 am »
After user lamaral posted a flash image of their Samsung UCCM over in the giant thread about those units, I embarked on attempting to reverse engineer as much of the unit as possible, and have spent way too much time in the past week on that endeavour. It was not a fruitless effort though, there are a great many undocumented commands in the firmware, some of which may be useful for those trying to repair units or otherwise mess around with them. I'm not sure this is the best forum, but it seems as good as any other, move the topic if necessary...
Unfortunately, one of the main things I was trying to conclusively determine - the complete format of the 'TOD' packet - still eludes me. This packet appears to be sent to the microcontroller periodically by the FPGA, but isn't used for anything other than to dump it to the console, so the only thing I was able to determine about it was the header structure and that it contains a timestamp in payload bytes 7-10. A slightly-parsed output can be enabled using 'UDP EN', but it doesn't do anything to illuminate the meaning of the payload.
Much else about the internals has been discovered, and if anyone has any questions or specific avenues of investigation, I can look into it further, but I think I have taken this about as far as I intend to, so I'm going to leave it at more or less documenting the CLI commands which appears to be the only truly useful thing to come out of this.
I have attached my Ghidra project if anyone is interested in continuing that effort.
I did try most of these commands on the Trimble unit I have. `UDP EN` seems to do something, though I don't have spare cables to connect it to an antenna and find out if it is useful. A couple of the other undocumented commands do exist there too, but nothing particularly interesting. Unfortunately I was unable to find a DEBUG mode or enter the bootloader.
All main CLI commands:
Samsung UCCM (Universal Core Clock Module) CLI commands
Mainly determined by reverse engineering. Thank you lamaral@EEVBlog for providing your firmware dump and inspiration to embark on this, and to the NSA (!) for open-sourcing Ghidra which was instrumental in this work.
Notes:
  - Where available, I have only include the unabbreviated command names here to attempt to aid in understanding. Many (but not all) allow abbreviated versions.
  - 'Standard' notation is used, parameters in brackets [] are optional, those in angle brackets <> are required, unless part of the command in which case they are always required
  - * indicates command requires TESTMODE be enabled first
  - Effects are mostly the result of experimentation and guesswork
*** USE AT YOUR OWN RISK. DURING TESTING I WAS ABLE TO GET MY UNIT TO GO INTO EFC EXCEED AND WAS UNABLE TO RECOVER IT. EVENTUALLY IT CAME GOOD AFTER FIDDLING AND POWER CYCLING, BUT YMMV ***
MAIN CLI
HELP
  display (incomplete) list of commands
DEBUG
  enter debug mode (see debug_commands.txt)
RESET [P|T] [wdt count]
  reset to bootloader
  - with T, 'watchdog test' - enter infinite loop, WDT should reset
  - with P, not sure, possibly reset the saved config, adds message "FPGA Erase"
DIAG:BUILD:VER?
  print a version number, doesn't match other version numbers found
  - Note: 'long form' of command is not supported
DIAG:BOOT:VER?
DAC*
  print DAC test mode state and current value
DAC TEST [ON|OFF]*
  enable/print DAC test mode (enable writing of DAC values)
DAC W <hex value>*
  write hex value to DAC
DAC R*
  read current DAC value
WDG MODE [ON|OFF]*
  print current watchdog mode
  - with ON/OFF, set watchdog mode
WDG TIME [seconds]*
  print current watchdog timeout
  - with value, set timeout
WDG TEST*
  enter infinite loop, WDT should reset board after current timeout
PLL DIS*
  toggle PLL info display (see PLLDIS)
PLL CAL*
  PLL calibration routine
  - details unknown, takes approx. 5 minutes
PLL FAC*
  print some PLL seq(?) information
  Seq.s = 2 steps
      seq.0 = 6 : 0
      seq.1 = 3 : -5
  --> seq.2 = 3 : -5 (*)
      seq.3 = 2 : -8
      seq.4 = 0 : 0
      seq.5 = 0 : 0
      seq.6 = 0 : 0
      seq.7 = 0 : 0
      seq.8 = 0 : 0
      seq.9 = 0 : 0
  Current tAlpha = 8, tBeta = 32
  holdOverDurLimit  = 28800 sec
  holdOverDelay     = 0 sec
  holdOverActiveDur = 3600 sec
  standbyThr        = 60 sec
PLL SEQ*
  increment the PLL seq number
  - there seems to be code to handle PLL SEQ [+/-], but this didn't seem to work for me
PLL SEQ INIT*
  reinitialize the PLL
  - seems to be more aggressive but similar to PLL INIT
PLL OFFSET SHOW*
  print some PLL DAC/offset information
   Current Dac Offset = 360858 (0005819a)
  Current Dac Value  = 356166 (00056f46)
  Factory Dac Offset = 356284 (00056fbc)
  Hour Dac Offset    = 356284 (00056fbc)
PLL OFFSET SAVE*
  doesn't look like this does much, maybe write to flash config area?
PLL OFFSET WR <hex value>*
  write the provided offset to the 'Factory Dac Offset' and 'Hour Dac Offset' fields
PLL OFFSET CHANGE <[+/-]ppb_value>*
  print the rate off offset change?
  - change the pll offset by the given value
PLL HOLD*
  print holdover test mode
PLL HOLD [IN/OUT]*
  enter/leave holdover test mode
PLL HOLD TIME <[+/-]hours>*
  start holdover mode after given hours
PLL WARMUP*
  no idea
PLL ALIGN*
  no idea
PLL SHIFT*
  pll phase shift test (?)
PLLDIS <EN|DI> [EVEN|ODD]*
PLLDIS?
  enable/disable/get dumping of PLL state information
  - with even/odd, report on even/odd seconds respectively. with no option, report every second.
  *2021/01/12 00:10:46 : -12, 356787, 210.000, 35.000, 5.544, 5.091, 3.300, 1.248, 0, 1, 0, 0
                  TIME : tIE,   EFC, HoldDac(?), Temp,  5.5V,    5V,  3.3V,  1.2V, ?, ?, ?, ?
  print state of PLL state dumping
ALARM <EN|DI>*
  enable/disable alarms? no obvious effect.
STATUS <EN|DI>*
  no obvious effect
PF?/FF?/NORMAL?/ABNORMAL?/HOLDALARM?*
  print whether various GPIOs/alarms are enabled/disabled
TEST FPGA
  test the FPGA
TEST SFLASH
  erase the non-boot bank (!!) and test write/read to it. takes a few minutes. not recommended.
GPSCURRENT
  print current GPS module (I assume) current consumption
GPSSAT
  print currently visible (tracking?) PRNs
  8 10,35,13,42,16,43,18,43,20,50,23,51,26,40,27,36
TESTMODE <EN|DI>
TESTMODE?
  enable/disable/get TESTMODE (required for many commands)
RDL:MON <EN|DI>
RDL:MON?
  set/get no obvious effect
*IDN?
  print device type, serial number and version
ALARM:HARDWARE?
  print any asserted hardware alarms
  Possible: 0.5Hz|10MHz|Selftest|Power|EFC Limit Exceed|Internal Ref|FPGA
ALARM:OPERATION?
  print any asserted operation alarms
  Possible: Antenna|Holdover Exceed|Holdover 60minutes|EFC Near Limit|GPS Comm|GPS 1PPS|EXTREF
DIAGNOSTIC:OUTPUT <ON|OFF>
  no obvious immediate effect, presumably prints additional information to the serial
DIAGNOSTIC:ROSCILLATOR:EFCONTROL:RELATIVE?
  prints a floating point value, not sure the exact meaning, perhaps ppb of EFC applied?
  -1.469E+1
DIAGNOSTIC:ROSCILLATOR:EFCONTROL:DATA?
  prints a floating point value, not sure of the meaning, it is 0 for me
DIAGNOSTIC:LOOP?
  print frequency offsets of available references
  OCXO : +3.065E-9
  EXT : Unavailable
DIAGNOSTIC:TCODE:[ERROR|STATUS]:[A|O]MASK <decimal value>
DIAGNOSTIC:TCODE:[ERROR|STATUS]:[A|O]MASK?
  no idea what these do, but sets/gets some values
DIAGNOSTIC:LOG:READ? <decimal value>
  would expect to print a partial log, but doesn't
DIAGNOSTIC:LOG:READ:ALL?
  print all entries in the flash status log
DIAGNOSTIC:LOG:CLEAR
  clear all entries in the flash status log
DIAGNOSTIC:HOLDOVER:DELAY?
  print holdover delay (seconds)
GPS:POSITION <latlong in awkward format, see the output of GPS:POSITION?>
GPS:POSITION?
  get/set GPS position
GPS:POSITION:HOLD:LAST?
  print a GPS position, probably the last surveyed one?
[LINK|GPS]:REFERENCE:ADELAY <time in seconds, 1e-9 notation>
[LINK|GPS]:REFERENCE:ADELAY?
  set/get reference antenna delay
SYNCHRONIZATION:INPUT:PPS:DELAY <time in seconds, 1e-9 notation>
  set PPS input delay (not sure if applies to GPS PPS or EXT PPS?)
  get PPS input delay
DIAGNOSTIC:ANTENNA:CFEED <ON|OFF>
DIAGNOSTIC:ANTENNA:CFEED?
  enable/disable/get antenna power supply
GPS:REF:ANT:CURR?
  print antenna current
GPS:REF:ANT:[SHORT|OPEN]:CURR:THR <current in ma (float)>
GPS:REF:ANT:[SHORT|OPEN]:CURR:THR?
  get/set upper/lower current threshold for antenna alarm
GPS:SATELLITE:TRACKING:COUNT?
  print the number of currently tracked satellites
GPS:SATELLITE:TRACKING:EMANGLE <angle>
GPS:SATELLITE:TRACKING:EMANGLE?
  set/get the elevation mask angle
GPS:SATELLITE:TRACKING:[INCLUDE|IGNORE] <PRN> [PRN] ...
  include or exclude PRNs from being used in the time solution
GPS:SATELLITE:TRACKING:[INCLUDE|IGNORE]:ALL
  include or exclude ALL satellites
LED:GPSLOCK?
  print state of 'lock' LED
SYNCHRONIZATION:HOLDOVER:DURATION:STATUS:THRESHOLD
SYNCHRONIZATION:HOLDOVER:DURATION:STATUS:THRESHOLD?
  set/get holdover duration before going into alarm i think
SYNCHRONIZATION:[T|F]FOM?
  get time|frequency figure of merit
  for time this is discretized into orders of magnitude in ns
  for frequency it is basically PLL lock/unlock
SYNCHRONIZATION:REFERENCE:[ENABLE|DISABLE] <GPS|EXT>
SYNCHRONIZATION:REFERENCE:ENABLE?
  set/get enabled references
SYNCHRONIZATION:TINTERVAL?
  print what i believe is the current phase error according to the pll
SYSTEM:PRESET
  reset all (?) system state to defaults
SYSTEM:PON
  power-on-reset the board
SYSTEM:STATUS?
  print system status 'dashboard'
SYSTem:COMMUNICATION:[SERIAL1|SERIAL2]:BAUD <baud rate>
SYSTem:COMMUNICATION:[SERIAL1|SERIAL2]:BAUD?
  set/get baud rate of serial ports
SYSTem:COMMUNICATION:[SERIAL1|SERIAL2]:PRESET
  reset state of serial ports
OUTPUT:MODE?
  print output mode (GPS or EXT)
OUTPUT:TP:SELECTION <PP1S|PP2S|8K|NONE>
OUTPUT:TP:SELECTION?
  set/get output timepulse format. 8k doesn't seem to work for me, but is accepted.
OUTPUT:STANDBY:THRESHOLD <decimal value>
OUTPUT:STANDBY:THRESHOLD?
  set/get output standby threshold
OUTPUT:STANDBY:TIE:THRESHOLD <decimal value>
OUTPUT:STANDBY:TIE:THRESHOLD?
  set/get output time-interval-error threshold
OUTPUT:REFERENCE?
  get time reference (NONE|GPS|EXT|OCXO) used for output
OUTPUT:ACTIVE:[ENABLE|DISABLE]
  enable/disable output?
OUTPUT:ACTIVE:HOLDOVER:DURATION:THRESHOLD <seconds>
OUTPUT:ACTIVE:HOLDOVER:DURATION:THRESHOLD?
  set/get output holdover threshold
OUTPUT:STATE?
  get status of output (BLOCK|Normal|Abnormal|UNLOCK)
SN
CHANGESN
  get current SN / offer to change
STAT
  print general status information
STATUS
  all signs point to this following the same code path as STAT, but i get different results. not sure how.
POSSTATUS
  print GPS status information (pos, DOP, tracking, antenna)
TOD <EN|DI>
  enable/disable 'time of day' dump every 1s
  structure unknown for now
UDP <EN|DI>
  enable/disable 'udp' dump every 1s
  structure unknown for now, seems to be the same data as TOD but with decoded header, but not payload
  working on this...
TIME:STRING?
  print the current time in nonstandard format
  2021/01/10 12:25:19
REFERENCE:TYPE GPS|EXT|NONE
REFERENCE:TYPE?
  set/get the reference type
REFERENCE:PRIORITY?
  no-op
DIAGNOSTIC:REFERENCE:SELECT?
  print the currently selected reference (GPS|EXT)
DIAGNOSTIC:MODE:ID?
  print the current mode (?). directly from GPIO1 pin 5
  if set, EXT(WCDMA), else GPS(WCDMA)
PULLINRANGE <decimal value>
PULLINRANGE?
  set/get OCXO pull-in range in ppb
SBAS:SAT <EN|DI>
SBAS:SAT?
  enable/disable/get SBAS
IMAGE:INFO?
  print information on flash images
IMAGE:ACT <BANK0|BANK1>
  i think this activates the given image for next boot, but since i wiped my bank0, it is a no-op for me. use at your own risk.
IMAGE:DEL <BANK0|BANK1|ALL>
  delete the given image(s)? seems risky...
All DEBUG mode commands:
Samsung UCCM (Universal Core Clock Module) DEBUG commands
Notes:
  - Debug commands are case-sensitive and must be lowercase
  - While in debug prompt, additional logs are printed (eg. pll state changes)
DEBUG CLI
help
  print (incomplete) list of commands
exp
  i don't know what this does, but it seems dangerous. sets an exponent or offset or something for something.
cls
  clear screen
image info
  print flash bank info
image del <bank0|bank1|all>
  presumably does what it says. i didn't test it.
image act <bank0|bank1>
  presumably sets the active bank
scpi
  return to normal cli
reset [P|T] [wdt count]
  reset to bootloader
test
  test something. not sure what or what the output means.
wdg mode [on|off]
wdg time [seconds]
wdg test
system
  print system state information
  TIME        : 2021/01/11 22:53:50 (GPS)
  Temperature = 33.500
  SYSTEM MODE : WCDMA
    ACT STATE : MASTER (non-Protect)
          REF  : GPS_REF (ok)
      x-ACT in : L(other)
        A/S in : H(slave)
      Ref_sel : L(GPS)
      mode_id : H(WCDMA)
  Task Counts : DebugTask(518037), EngineTask(607414)
                TodTask(517072), CtrlTask(1985673)
                PllTask(1035348), BackUpTask(1029767)
                TodEvenTaskCount(1031624)
    Int Counts : pllIntCount(51816 - 51816), todIntCount(25907)
                dacIntCount(5181602 - 5181601), twIntCount(51815 - 51815)
  TIME := 2021/01/11 22:53:50
  LAT   := N 49:00:00.000
  LON   := W 123:00:00.000
  HIGT := +18.018 m
system init
  "Backup datas will be set to factory values and it will be applied after reset."
  presumably resets stored config
ver
  print firmware and hardware (fpga) versions
   F/W Version := 1.0.0.3
  H/W Version := 1.0.0.2
  Description := DESCRIPTION TEST
  - Samsung & SpringWave
time
  print current time
time stemp
  this commands toggles a variable, but i don't know what it does
md <hex address> [decimal block count]
  dump memory starting at address. blocks are 256 bytes.
mm <hex address> <hex value> <value length>
  write to memory. i didn't mess with this, i'm fairly sure of the format but didn't test it.
  seems to not allow writes to addresses below the flash entry point, which is weird, since
  flash isn't writable this way, so this would only be useful for writing to peripherals?
  max value length is probably 4 bytes as it is read into an integer
ram
  print the test type, size, and values of the memory test
fpga <r|w> <address> [value]
  read/write from the FPGA registers
fpga test <address>
  test the fpga? not exactly sure what it does. i think it might be a dedicated fpga command
  that echoes the request byte back, and loops over all bytes checking this
fpga dup<rx|tx> [en|di]
  without EN/DI, seems to print some info about the last packet received/transmitted?
  not sure what EN/DI does
fpga reset
  sends a command to the fpga, presumably resetting its state
fpga clock
  print the 'clock fail byte'
eng dis
  toggle dumping of u-blox debug information
eng [en|di]
  enable/disable the GPS engine (pps processing / GPS reference)
eng hex
  toggle hex dump of raw u-blox frames
eng init
  send the initialization commands to the GPS module
eng baud [9600|19200|38400]
  set the u-blox & USART baud rate and re-init engine
eng msg en <id 1-7>
  enable u-blox periodic messages (see the u-blox 6 Receiver Description document)
  1 = NAV_STATUS
  2 = NAV_SVINFO
  3 = NAV_POSLLH
  4 = NAV_POSECEF
  5 = TIM_TP
  6 = TIM_SVIN
  7 = NAV_DOP
eng reset <clear|set>
  clear/set the GPIO attached to the u-blox ~reset line
  reset will be detected and recovered
eng restart
  restart the engine (not sure how this differs from init)
eng cfg
  query various CFG blocks from the u-blox and print to console
eng ant <flags> <pins>
  set u-blox CFG-ANT values
# NOTE: Changing any of these will probably just stop the GPSDO from working
# this is the internal GPS->FPGA interface, and doesn't compensate for the settings
eng pps period <decimal us>
  set u-blox CFG-TP interval
eng pps width <decimal us>
  set u-blox CFG-TP length
eng pps sign <+1|0|-1>
  set u-blox CFG-TP status (PPS polarity)
eng pos
  print current GPS position and mode
eng pos mode [none|survey|fix]
  set u-blox CFG-TMODE2 timeMode. none seems to set fix mode.
eng pos para [svinacc|svindur] [decimal value]
  with no parameters, show the CFG-TMODE2 parameters svinMinDur and svinAccLimit
  with parameters, set the values
eng pos sbas <en|di>
  enable/disable SBAS
dac
  print dac testmode state and current value
dac test [on|off]
dac w <hex value>
  write hex value to DAC (requires DAC test mode)
dac r
adc dis
  print raw AVR32 ADC values (voltage monitors)
adc con
  print ADC voltages
pll state
  print pll state information
pll ref <gps|ext>
  set the PLL reference source
pll dis
  toggle dumping PLL state every tick
  *2021/01/12 01:14:22 : TIE=-17, FIR=-6.019, EFC=357107, HoldDac=-26.200, Temp=34.000, 5V=5.091
pll mon
  toggle PLL monitor?
pll cal
  start PLL calibration cycle
pll fac
  Seq.s = 2 steps
      seq.0 = 6 : 0
      seq.1 = 3 : -5
      seq.3 = 2 : -8
      seq.4 = 0 : 0
      seq.5 = 0 : 0
      seq.6 = 0 : 0
      seq.7 = 0 : 0
      seq.8 = 0 : 0
      seq.9 = 0 : 0
  standbyThr        = 60 sec
pll maxseq <seq>
  set the maximum sequence?
pll seq <seq> <val1> <val2>
  set the sequence values shown above for a given seq #
pll fac init
  not sure, doesn't seem to reset any of the values show in pll fac
pll seq init
  move pll to initial state
pll offset show
  print PLL offset values
  Current Dac Offset = 357098 (000572ea)
  Current Dac Value  = 357130 (0005730a)
  Hour Dac Offset    = 357258 (0005738a)
pll offset save
pll offset wr <hex value>
pll offset change <[+/-]ppb_value>
  print the rate of offset change?
pll hold
pll hold [in|out]
pll hold time <[+/-]hours>
pll warmup
  no idea
pll align
  no idea
pll freerun <on|off>
  put pll into/out of freerun mode
pll shift
tod dis
  toggle display of TOD packets in a slightly different format from UDP EN or TOD EN
  [ TOD (4d27bdee) : 2021/01/12 01:29:18 - c5 00 80 00 00 00 00 28 1c 52 00 00 20 60 c1 91 00 00 00 00 00 00 00 00 00 00 00 4d 27 bd ee 00 12 60 00 05 87 00 00 00 00 08 51 ca ] 12~13
tod send <on|off>
  enable/disable sending of TOD packets between FPGA and AVR32
tod cmd
  print a Tod command count
tod cmd clr
  clear the Tod command count
log all
  print the full event log from flash
log last
  <unimplemented>
log add <message>
  add the provided message to log. spaces don't seem to be supported.
aging factor <holddac|dac|none>
  select the aging factor that is in use
aging db
  print saved aging data. entries seem to be stored every 10 minutes, save timestamp, temp and holdDac value
  slopeDAC = -0.737, Zone_cnt = 82, dacAging = -8.994E-3/sec,
  [058] 1294449224 2021/01/12 01:13:44 34.000 357143.200
  ----------------------------------------------------- 0 -
  dacAging = -8.994E-3/sec, holdDacAging = +0.0E+0/sec
aging wr <pos> <timestamp> <temp> <holdDac>
  manually write an entry to the aging db
aging fpgatime
aging fpgatime?
  set/get fpga 'seccount' presumably secs since startup
aging delay
aging delay?
  set/get aging init delay
aging unit
aging unit?
  set/get aging unit count
aging sim
  start aging simulation (??)
  hangs GPSDO long enough that i power cycled it
ant val
  read antenna adc values
  ShuntVoltage = 7.340mV
  BusVoltage = 5.144V
  power = 7.570mW
  Current = 29.400mA
ant thr
  print antenna alarm thresholds
ant thr <open|short> <val>
  theoretically should set the threshold values, but i can't figure out how to use it
alarm <all|hard|oper>
  print alarms
alarm poll <on|off>
  enable/disable periodic printing of alarm state
sat
  dump satellite information (identical to SYSTEM:STATUS?)
port
  print state of various I/Os
power
  print system voltages (raw adc values)
power <5.5|5|3.3|1.2|all> <on|off>
  set manual power alarm on given rail(s)
clkalign
  reset clock alignment? not sure.
8k
  run 8k test procedure? not sure what any of it means/does.
All Bootloader commands:
Samsung UCCM (Universal Core Clock Module) BOOTLOADER commands
Bootloader password: 123qwe
I have been unable to access the bootloader on my unit for some reason. Maybe something with my test setup.
It should be possible to enter it by pressing 'enter' while prompted and entering the password.
help
test
md
mm
fclr
image load <bank0|bank1>
image del <bank0|bank1|flash|all|*>
image crc <on|off>
fusing <bank0|bank1> <check|force>
go
« Last Edit: January 12, 2021, 02:35:40 am by ve7xen »
73 de VE7XEN
He/Him
Offline lamaral
Re: Samsung UCCM GPSDO reverse engineering
« Reply #1 on: January 13, 2021, 07:20:04 pm »
Thank you for the invaluable contribution, ve7xen :)
The following users thanked this post: ducus
Offline cdev
« Reply #2 on: January 24, 2021, 02:49:07 pm »
I have some dumb questions that I have not been able to find the answer to.
Is there a power connection for this GPSDO via a header that does not utilize the FPC connector?
2.5 amps seems like a lot of current to ask the FPC to carry, even if its divided over multiple traces, and only for a short period of time when it's warming up...
There is an additional header J6, which isn't mentioned in the literature on it.
Is that a UART and/or a 12V serial port?
Does it use the PC layout for a serial port to DB9 cable?
I recently got a Samsung UCCM GPSDO, and I am still waiting on the FPC adaptor board.
It looks similar to this board pictured, with some minor differences. It uses what appears to be Samsung's own OCXO.
I am attaching a PDF from an earlier thread which you all likely already have.
Also more info here:
https://time-nuts.febo.narkive.com/Tm2BCk3v/samsung-gpsdo-chinese-surplus
Looking forward to exploring the additional signals present. Which ones would you expose on an external jack, besides the usual ones?
I'm going to wire up a hookup for my MSO which has two analog inputs. I am also thinking of putting a temperature, humidity and barometric pressure sensor inside the case.
Thank you!
« Last Edit: January 24, 2021, 02:56:23 pm by cdev »
    • VE7XEN Blog
« Reply #3 on: January 25, 2021, 10:11:10 am »
I don't think so. The FPC is the only interface to the bigger system these modules are meant to be a part of.
It does, that's why they parallel 7 power traces and a bunch of grounds. 0.5mm flat flex is typically rated for 0.5A/trace, so that's more than enough. If you're designing a board it's no big deal to parallel all the traces, but kind of a pain when you're working with it on the bench, so I do agree I'd rather have a single more robust power connection, but if you want one you will probably have to bodge it in.
I haven't traced out J6 (only did software reverse engineering, since my only module is in 'production' for my NTP server), but it definitely doesn't have any power inputs on it. It's all 3.3V. Presumably it's a JTAG. It could be a UART, but with two UARTs already brought out to the FFC, and so many pins, I doubt it. Interestingly, the Trimble module also has what appears to be a debug footprint marked J6, but it is SMT 14-pin, just curious that it uses the same designator.
73 de VE7XEN
He/Him
Offline cdev
« Reply #4 on: January 25, 2021, 11:32:19 am »
Strange that there are no manuals for it out there.
Offline KC0SKM
« Reply #5 on: February 01, 2021, 02:41:32 pm »
I have searched and all I have is some basic info on this product and gleamed from similar too UCCM modules... if you want I can share a google doc.. of links and things I have found. Looks like you are just getting going on this me too --- keep me in the loop if you find any info on this board...
Offline cdev
« Reply #6 on: February 01, 2021, 03:26:30 pm »
UCCM stands for Universal Core Clock Module  (thsnks to ve7xen for that info) So that may be helpful in finding out more.
I'd be interested in getting a manual for it. The extra logic signals are probably for indicator LEDs. Thats what I am likely going to connect them to, anyway.
« Last Edit: February 01, 2021, 03:28:08 pm by cdev »
Offline lamaral
« Reply #7 on: February 01, 2021, 03:55:46 pm »
I will leave here two links for manuals of systems that use the UCCM modules internally. From one of the manuals, you can see that the modules work in pairs:
https://fccid.io/A3LSMM-BMAA022000/User-Manual/User-Manual-1688369
https://fccid.io/A3LSLS-2A00002100/User-Manual/user-manual-1266043
If you click around in the fccid.io page, you can find other documents (i.e. pictures of the modules inside the bigger equipment), but no dedicated manual for the UCCM as far as I could see.
The following users thanked this post: ve7xen, FransW
Offline glosair
« Reply #8 on: January 12, 2022, 06:16:45 pm »
Thanks for the great work,
I have just got a Samsung UCCM and though I'd ask Samsung for the documentation directly.
They have said they should be able to get the documentation to me in 3-5 working days if they have any.
It was a very very long support call but the guy got the idea in the end.   :-DD
    • VE7XEN Blog
« Reply #9 on: January 12, 2022, 07:49:21 pm »
Oh wow, I would never even have thought to contact the OEM for such a part  :-DD. Good luck!! Please pass on anything you find out.
73 de VE7XEN
He/Him
The following users thanked this post: cdev, glosair
Offline cdev
« Reply #10 on: January 15, 2022, 02:02:43 am »
Thank you!
If any of you Samsung guys read this you should know that your GPSDO was put up against a bunch of other companies GPSDOs and it was my strong impresson that it came out near the very top. Which is pretty impressive because it was an excellent value, cost wise, at least for me, and some of the other ones are very expensive. Way out of my price range.
You should be very proud, of your super accurate clock. GPSDOs are used everywhere in labs everywhere. For example at the Jet Propulsion Laboratory in Pasadena, CA, a lab that is managed by the University of California for NASA. Its where the Mars rovers originate.
The data was contained in a thread here around two years ago and was a collaboration between users @texaspyro and @tvb. also of leapsecond.com
I also have a TruePosition GPSDO, which I also like a lot. Your GPSDO is much more sensitive though with its ublox GPS. I don't know which is more accurate as far as adev performance. I think both are at least an order of magnitude better than most of our various users time and frequency measuring equipment are capable of measuring. People here keep building their own GPSDOS, its kind of a design challenge that has become a sort of competition.
« Last Edit: January 15, 2022, 02:25:39 am by cdev »
Offline glosair
« Reply #11 on: January 30, 2022, 08:13:23 pm »
Got a reply..
Dear Tim
Thank you for contacting Samsung UK's CEO office.
Whilst we recognise your endeavours re sustainability regrettably the information you have requested is not available to provide. This is not published information to be able to share unfortunately.
We are sorry that we cannot assist further.
Kind regards
S*** A***
President & CEO Escalations
Samsung UK & Ireland
Offline cdev
« Reply #12 on: February 01, 2022, 02:45:19 am »
"sustainability"?
Boy, thats an ambiguous word these days, it means so many things to different people. Sometimes its a red flag for me.
    • VE7XEN Blog
« Reply #13 on: February 01, 2022, 10:16:05 am »
I'd assume that glosair said something along the lines of "I want to try to repurpose this equipment so it doesn't end up in landfill", which tracks with "sustainability".
I'm impressed they got a response at all, to be honest that's not the sort of query I expect them to even bother answering these days.
73 de VE7XEN
He/Him
The following users thanked this post: ch_scr, glosair
