Author Topic: Calibrating a scope with out the right tools.  (Read 3785 times)
Offline 2N3055
  • Country: hr
Re: Calibrating a scope with out the right tools.
« Reply #25 on: February 10, 2022, 03:47:54 pm »
So, digital scopes cannot represent the fine details as well. To optimize transients response a system approach is needed, pulse generator, connections, scope will each  affect the pulse rise time and abberation.
Sure they can. In last 30-40 years lots of stuff happened.
Same signal source with attenuator. On a modern 12Bit scope.
That being said, I'm still absolutely amazed what those wizard in Tek could do in purely analog domain. Absolute genius..
Offline David Hess
  • DavidH
« Reply #26 on: February 10, 2022, 11:45:49 pm »
My ancient DSOs handle fast rise signals just fine.  I think it only became a problem with modern real time only DSOs that eschew equivalent time sampling.
Offline ZenwizardTopic starter
« Reply #27 on: February 11, 2022, 06:12:06 pm »
This test will be interesting to run on my 7854 once I get the calibration tuned up on it. both of the 7854's I have a WAY off in the digital sections.
You Tube Link - Fixing broken Things
« Reply #28 on: February 12, 2022, 10:57:55 am »
No attenuator, no special settings just plug and play with a 1 GHz 8 bit DSO and Leo's pulser.
However measured risetime is 10x Leo's spec.
