Here is my take on the 3458a updates.
I have replaced:
-Inguard supply electrolytic capacitors
-Outguard supply electrolytic capacitors
-Line filter
-Rifa capacitors
-Added sockets
-Settings FRAM installed
-Firmware updated
-Added option 001 memory
*The ZIF socket required moving 1 resistor and 1 capacitor to the underside of the board. I will be doing various projects with this one, so wanted the cal RAM easy to swap.
*The cal SRAM has been backed up to PC
To Do:
-New fan
-Put labels on the firmware chips on top of the aluminum window covers
-Source a fuse binding post that is missing
FRAM board for the cal socket, or just punt and put a new Dallas SRAM in for now Installed via a socket adapter
-5000 different volt nuttery tests and fun times starting with drift tests
-To be continued...
Look at the date code on this old Dallas chip.
It's still holding the data.
