First question is why do you think the STEL-1173 is dead?
Second question is where did you look for replacement chips?
Third question is have you tested the tube to make sure it's alive? There's no point replacing the STEL-1173 if the tube is dead.
Back in 2014 when I was trying to fix my FTS-4065A, I was looking for the same chip. Mine was the PLC44 version and it was easier to find the DIP version. I looked at a PLCC -> DIP adapter, but the spacing was very tight and I really didn't want to use an adapter. I eventually took a chance and bought the PLCC chip from Aliexpress. It worked out fine. The chips were genuine and everything was good. The link doesn't work anymore, but using google shows more hits than searching Aliexpress directly.
Don't forget to buy two or three in case you get a dead one. You might also want to solder in a socket so future replacements are trivial.
Good luck!
Ed
