Hello,
New frequency generator 1hZ at 15 GHz from BG7TBL called WB-SG1-OPT15G 1Hz at 15 GHz! The output level setting is adjustable compared to the 8 GHz model with the output level fixed.
https://www.ebay.com/itm/WB-SG1-OPT15G-1Hz-15GHz-Signal-Source-Signal-generator-Power-ADJ-OCXO-BG7TBL/233507852253-----
Characteristic:
overview:1Hz-15GHz wide band output,10M-15GHz with amplifiler adjust,OCXO inside,
support extern connectfrequency stanard
CH1 frequency range:1Hz-200MHz
CH1 step:1Hz-19.999999MHz/1Hz,20MHz-200MHz/10Hz
CH1 output amplifiler:3.3Vpp
CH1 plug type:BNC
CH2 frequency range:10MHz-15GHz
CH2 step:10Hz
CH2 reference output power:+5DBM- -7dBm@1GCH2 output impedance:50 OHM
CH2 plug type:SMA
inside frequency stadnard:10MHz
inside frequency stadnard type:OCXO
inside frequency stadnard ageing:0.5Hz/year
10M frequency output power:5dBm
extern frequency input range:0dBm to +20dBm
run mode:CH1 frequency mode,CH2 frequency mode,CH1 sweep mode,CH2 sweep mode
front panel:MODE,change mode
ENT:input data
<>^V:left/right/up/down key
CH1:channel 1 output
CH2:channel 2 output
rear panel:10M REF INPUT:extern 10M input
10M REF OUTPU:10M output
USB:USB port
STD ADJ:inside OCXO frequency adjust
power switch
dc plug
power :DC11.7-12.5V,star:less than 0.5A,stabilize:less than 0.25A
weight:350g
accessory: DC12V adapter 1pcs
Regards
Diabolo
