Author Topic: AVK-6 ultra low noise coaxial cable  (Read 2392 times)
Offline shodan@micronTopic starter
  • Country: ru
  • Deleted account
« on: June 26, 2021, 07:31:57 pm »
void
« Last Edit: July 14, 2021, 05:20:17 pm by shodan@micron »
Deleted account
The following users thanked this post: MiDi, ch_scr
Online TimFox
Re: AVK-6 ultra low noise coaxial cable
« Reply #1 on: June 26, 2021, 08:11:59 pm »
To understand the specification:  what voltage is across the cable when the noise is measured during vibration (10 and 40 G acceleration)?
I first thought the dielectric is coated with graphite, from the picture, but the spec reads "conductive fluorosiloxane" for the black layer.
Offline bsw_m
  • Country: by
« Reply #2 on: June 26, 2021, 08:19:34 pm »
what voltage is across the cable when the noise is measured during vibration..
Noise specs:
<30uV at 10G acceleration and 40Hz test freq
and
<250uV at 40G acceleration.
I also want to note that in cables of this series (AVK*), a conductive layer of graphite has never been used.
Special compositions "ФС" are used - special conductive fluorosiloxane elastomers.
« Last Edit: June 26, 2021, 08:21:13 pm by bsw_m »
Online TimFox
« Reply #3 on: June 26, 2021, 08:59:48 pm »
Yes, I understood the frequency and acceleration values, but was wondering if this was done at 0 V across the cable.  With DC on the cable, the noise would go up during the vibration tests.
Online TimFox
« Reply #4 on: July 05, 2021, 05:20:03 pm »
How do you remove the black conductive layer over the dielectric?  Only by careful knife work?
Offline Zoli
  • Grumpy old men
« Reply #5 on: July 06, 2021, 04:07:42 am »
More detailed picture.
The conductive fluorosiloxane elastomers, is elastic, resin like compound with very strong tie with PTFE.
I don't know how USSR scientist create so strong link with PTFE... it looks like black voodoo magic  :-//  To terminate a cable end and provide low leakage that layer must be removed, but it is hard.
If the PTFE is etched before bonding, the bond can be pretty tough - don't ask me how I know.
As sidenote, the etchant isn't really high-tech: naphtalene based...
The following users thanked this post: Mickle T.
