Author Topic: Input impedance in Fluke autoranging meters  (Read 19540 times)
Offline e61_phil
Re: Input impedance in Fluke autoranging meters
« Reply #25 on: October 25, 2017, 08:23:02 pm »
Sorry, I'm not allowed to post photos.
The setup isn't very special. A 3458A, a 34470A and a FuG high voltage supply (HCP series with high stability and low noise options). Everything is connected with coaxial high voltage cables and 10kV-SHV Plugs. The HV probes are simply connected to a wire which is soldered to a 10kV-SHV jack.
The DIY 1000:1 divider is built up of 20 selected Caddock USF 371 resistors and a 100k Vishay S102 (or Z201?)+some Rhopoint PWW for fine tunning. Worst case uncertainty calculation gives about 35ppm at 10kV, but it seems to be much better.
Offline FlexibleMammothTopic starter
« Reply #26 on: October 26, 2017, 01:18:57 pm »
I'm genuinely amazed by the precision of the Testec probes. With fluke, it seems some kind of lottery - you may or may not get lucky... :-BROKE
Thank you so much for the 50mv/500mV measurements. I do not have the means to do these at home, probably need to take my meter to the lab at university. Now I have something to compare to!  :clap:
Offline HighVoltage
« Reply #27 on: October 26, 2017, 01:46:11 pm »
The DIY 1000:1 divider is built up of 20 selected Caddock USF 371 resistors.
Wow... they are 30 Euro a piece !
Is that correct?
« Reply #28 on: October 26, 2017, 01:49:48 pm »
Is that correct?
Well as he can't post pictures, this is a cal lab/workplace/whatever. I doubt they care if they can afford both a 3458A and a 34470A   ;D
Offline HighVoltage
« Reply #29 on: October 26, 2017, 03:30:19 pm »
Is that correct?
[/quote]
Well, I also have a 3458A and a 34470A and know about expensive equipment. Somehow I just did not expect this high price for this resistor. But I guess one has to spend the money to get this precision divider.
I have a few Tektronix high voltage probes P6015A and a couple Fluke 80K-40.
It would be nice to have such a precision divider to check the calibration of the probes.
« Reply #30 on: October 26, 2017, 03:56:00 pm »
Mark me down as impressed and envious :-)
You're not the only one there!
Is 30 bucks for factory-preselected resistors? If not, that setup might have cost even more...
Offline fcb
    • Electron Plus
« Reply #31 on: October 29, 2017, 04:34:09 pm »
Such a shame about the pix.
I looked up FuG - their gear looks amazing. Very cool that they can build a 100+ person company making that stuff.
« Last Edit: October 29, 2017, 04:37:17 pm by fcb »
Offline HighVoltage
« Reply #32 on: October 30, 2017, 12:06:16 pm »
Yes, FUG is an amazingly good company. And when I repaired my 12.5 kV unit, I got all the support I needed, although this instrument is out of production for a long time.
Offline emg
  • Country: ir
« Reply #33 on: February 17, 2024, 05:55:59 am »
thanks for your answer.
My HIOKI clamp meter and UNI-T DDMs seems to use similar divider therefore having variable input resistance.
Offline EC8010
« Reply #34 on: February 17, 2024, 09:26:17 am »
I just checked my Fluke 89 IV direct voltage ranges and got 10.991M, 10.092M, 10.002M, 10.002M.
