For the amplifier, the basic function appears to test ok. Some notes,
- The protection schottky is removed. Since there is not enough drop for jfe2140 VGS at working current (0.74V). The ESD protection of the jfe2140 is used, with hi and lo are tied across the zener.
- The 100R across the cascode collectors/ op-amp input, indicated in the ltspice model, is needed to keep voltages at the op input manageable.
Otherwise the circuit locks up/latches at startup, and the op-amp output will saturate (probably through the ESD protection of the jfe2140).
There is a question about loading the cascode collectors/op input with the 100R.
the voltage difference is small and will equal the Vos of the op amp.
But there will still be some current. eg. op Vos=1mV, 100R, => Ir=10uA. Albeit gain has already been added by this point.
A future board revsion will add the option for ordinary anti-parallel diodes to the inputs.
- The extra startup current source is not needed for mirror start/ doesn't influence the lockup behavior, with or without the 100R.
- A pnp (3906) also fits the pmos (bss84) footprint for the centre-leg of the mirror.
this makes it easy to test and compare bjt and fet approaches to the current mirror.
- Tested with lf411 and tl071a for op-amps.
mirror pfet bss84 -50V pmos. 60V. have smaller modern pfets but they are 30V.
source nfet bss138 nmos. 50V.
cascode bcm847 npn . Ic=100mA, VCEO=45V. (ssm2212 not tried yet.)
voltage ref soic-8 footprint. currently lt1021/5V with 10k/10k divider. can remove the divider when obtain a 2.5V ref (lt1019, max6190 etc).
1.33V on mirror emitters. 1.95V on centre source resistor pfet.
3.26V across the zener. (it's a 5.1V zener).
1.31V Vgs on mirror pfet
1.24V Vgs on source nmos
Vos of jfets 7.3mV with lf411 (weird - very poor Vos or Ib of lf411 ?).
4.6mV jfet Vos with tl071a and pnp for mirror.
4.9mV jfet Vos with tl071a and pfet for mirror.
- it would be nice to have a scope with integrated sig-gen for automated bode plots. With amplifier configured a buffer, and a square wave input, there's an overshoot that is corrected in around 5us.
For cmrr test, the plan was to use a +-18V bench supply for the amplifier, and power the board and auxillary op-amp, with a spare 34401a transformer + regulation.
lm78xx/79xx were chosen for regulation which are rated to 35VDC input.
But the 34401A transformer outputs 37-38VDC after rectification/filtering (Should have measured it, before committing to a design!).
lm317/lm337 could be bodged, but a new board will fix some other issues also.
The optocoupler/ b2b fet protection scheme looks ok. At least for +-100V over-voltage, using 200V to-247 fets, the fets shut off in around 500us-1ms.
There's a pcb routing error with a hv trace cross, with only pcb prepreg separation, rather than using the full pcb core thickness, which needs to be corrected.
