We often calibrate (and adjust) ADTS405s.
I don't have any currently in the lab with that error to confirm the repair path, but I certainly recall seeing it numerous times in the past. Performing a calibration adjustment to better align the Ps and Pt sensors is worthwhile, and should hopefully correct the error. If the root cause is sensor failure or instability, it may not be succesful or may return after a short time, but we generally find them to have quite reliable resonant sensors (a strong point for Druck).
Regards, Liam
