Author Topic: the smallest GPSDO in the world  (Read 1275 times)
Offline testpoint1Topic starter
« on: June 07, 2019, 03:53:04 am »
I designed, for the GPSDO, the "O" is VCOCXO, it can use the ref port generate 30.72MHz signal, use the 1pps port (TP2) generate 1-24MHz, signal, but the frequency must be divided exact of 24MHz, such as 4MHz, 8MHz, 12MHz etc, if you want to generate 10MHz, it can, but, terrible.
