Eventually, I am going to have to recoat the board with some protective layer. As I have never seen coatings like this on circuit boards before, I would also appreciate it if someone with experience could provide a recommendation on a product that they have used.
Today, My 8340A was broken . the reason is when I output 1000V, it is short with ground. the main fuse was broken, when I replace the fuse, it give out Err HV kV. it can output 1~100V. cannot output >100V.No I have to repaire it
