Author Topic: ADR1399 reference  (Read 144192 times)
Offline branadicTopic starter
  • Sounds like noise
Re: ADR1399 reference
« Reply #225 on: July 23, 2023, 06:02:36 pm »
Attached are multiple noise measurement of my ADR1399-PWM-DAC. Please replace µV by nV and you end up with about 2 µVpp.
-branadic-
« Last Edit: July 24, 2023, 03:50:17 pm by branadic »
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: Andreas, alm, ch_scr
Online Kleinstein
« Reply #226 on: July 23, 2023, 06:22:27 pm »
The noise looks good, with quite some of the peaks that are realatively short, possibly on a time scale where a little more filtering can help.
The real question is how good the long term drift will be for the TO46 version.
Let's hope it is driften less than the expected date for availabilty.
Offline deepfryed
« Reply #227 on: July 24, 2023, 11:17:28 am »
I have one ADR1399H-EBZ on order from Mouser, they say ETA end of September. Let's see.
Offline maxwell3e10
« Reply #228 on: July 25, 2023, 02:56:46 pm »
« Last Edit: July 25, 2023, 02:58:19 pm by maxwell3e10 »
The following users thanked this post: gamalot
Online gamalot
  • Correct my English
    • Youtube
« Reply #229 on: July 30, 2023, 06:30:50 am »
Four ADR1399KHZ from Digi-Key have just been delivered. My money is running out and I can't afford more.
I don't know what printing technology in 2023 can make the silk screen on top look so blurry and dirty! :(
« Last Edit: July 30, 2023, 06:35:39 am by gamalot »
Offline iMo
  • Country: bt
« Reply #230 on: July 30, 2023, 07:43:32 am »
Does not look like ADI's quality.. A fake?
Online gamalot
    • Youtube
« Reply #231 on: July 30, 2023, 07:56:17 am »
No, that just proves that they must be genuine, perhaps using eco-friendly printing techniques.  :-DD
  • Sounds like noise
« Reply #232 on: July 30, 2023, 08:17:16 am »
Looks really weird, as it is ADR1399 with LT logo instead of ADI logo, beside the poor printing quality.
-branadic-
Online gamalot
    • Youtube
« Reply #233 on: July 30, 2023, 08:58:31 am »
Even the thermal shield itself is not the same as before, what happened?  :-//
Offline iMo
  • Country: bt
« Reply #234 on: July 30, 2023, 09:19:55 am »
..ask your supplier..
Offline NNNI
    • YouTube channel
« Reply #235 on: July 30, 2023, 09:22:39 am »
@branadic
Have you already posted about the ADR1399 PWM DAC somewhere? I would love to learn more about it. I've recently been playing around simulating something similar using a passive 3 pole RC filter (3 stages of 10K/100nF C0G) which does indeed reduce ripple, but assuming I want 1uV settability, I would need a 23-bit resolution PWM signal. While that is possible, it pushes the PWM frequency very low, and I'm not sure how to make a practical implementation. Perhaps reduce settable resolution to 10uV?
@gamalot: Someone I know also just got an ADR1399, the printing was similarly crusty but the package looked to be in better shape.
« Last Edit: July 30, 2023, 09:26:02 am by NNNI »
Online Kleinstein
« Reply #236 on: July 30, 2023, 09:38:28 am »
From the picture the "printing" look like laser writen, with small dot matirx depressions.  Getting the LT logo is indeed odd.
Offline Andreas
« Reply #237 on: July 30, 2023, 09:47:01 am »
Hello,
it is all in the LM399 thread.
We are using Sigma Delta modulation for the PWM.
So it is possible to do several kHz @8 Bit PWM with 24 bit resolution.
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/msg2189460/#msg2189460
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/msg1955149/#msg1955149
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/msg2200098/#msg2200098
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/msg2082544/#msg2082544
with best regards
Andreas
The following users thanked this post: ch_scr, NNNI
Offline iMo
  • Country: bt
« Reply #238 on: July 30, 2023, 10:43:30 am »
@Andreas - perhaps you may open a new thread, like "x399 based PWM voltage standard" or something like that, and start with an update on the effort you, branadic and others did (like the latest schematics, firmware, etc). Otherwise it remains hidden in the rather long 399 thread..
Online Kleinstein
« Reply #239 on: July 30, 2023, 03:26:28 pm »
The PWM DAC part is not directly related to the reference, only indirectly through the voltage and noise level / stability expected.
AFAIR the LM399 10 V ref. part is not a classic PWM DAC, but in the 7 to 10 V amplfier feedback. This adds some limitations but also gets up from 7 V to 10 V without critical resistors setting the gain.
A more universal voltage source would more use 2x7 V to start with 14 V and than use a more conventional PWM DAC to get the 14 to 10 V (or another voltage) step.
Filtering would likely use film capacitors of some 1-10 µF, maybe even PP types to get fast settling / low DA.
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #240 on: July 30, 2023, 04:42:13 pm »
That's what i started building long time ago. There is an array of 10 LM399 to generate 14.1 V and to control the mains power supply that is built as a bootstrap amplifier to 19 V. There is an aluminum enclosure.
The 19 V will be used to implement the main PWM switch with a dual n-channel FET. I got the control board already with a 16 MHz MSP430 with isolated RS232, the PWM filter and the ripple compensation switch. So little missing. Just need to finish the main PWM switch and it will be a voltage calibrator.
The LM399 array has been powered for one or two years now and was already used for many different precision measurements.
Regards, Dieter
« Last Edit: July 30, 2023, 04:49:02 pm by dietert1 »
Online gamalot
    • Youtube
« Reply #241 on: July 31, 2023, 07:36:02 am »
Yes you can even feel the rough surface with your fingertip. At least on voltage reference components, I would prefer LT's logo to be there instead of ADI's.
Offline JodelJonny
« Reply #242 on: July 31, 2023, 09:37:11 am »
I just recieved my ADR1399 from DigiKey as well and it looks the same.
Unfortunately they were out of stock of the NOMC 8x10k Resistor arrays. If I can find one of those and a little bit of time I am going to build a second ADR1399 10V Ref.
Number 1 has been running for approx. 2800h.
I am very sorry that I havent uploaded any PCB/Gerber files yet. As this was my first real KiCAD project they are a mess and need signifacant work to be really usable.
Offline KT88
« Reply #243 on: July 31, 2023, 10:32:09 am »
The following users thanked this post: gamalot, ch_scr
Offline Grandchuck
« Reply #244 on: July 31, 2023, 10:44:27 am »
How about counterfeiting?  Laser marking might discourage it.
Online gamalot
    • Youtube
« Reply #245 on: July 31, 2023, 11:44:14 am »
There is a PCN related to the top marking:
https://www.analog.com/media/en/PCN/ADI_PCN_22_0025_Rev_-_Form.pdf
It seems that there is no mention of the change of the logo.
Offline NNNI
    • YouTube channel
« Reply #246 on: July 31, 2023, 04:28:42 pm »
In case someone is interested, a slightly more high resolution picture of the laser marking. The carbonization, I assume, is because of the laser process itself, but is it a useful side effect or intentional? One can only guess.
Offline Echo88
« Reply #247 on: July 31, 2023, 05:44:48 pm »
20€ on Mouser and the marking looks like piss in snow.
The following users thanked this post: Andreas, Nanitamuscen
Offline iMo
  • Country: bt
« Reply #248 on: July 31, 2023, 07:47:38 pm »
ADI hired a special tattoo saloon in Parañaque City..
PS: it could be it is a novel anti-counterfeiting technology..
Or, simply they reuse their existing laser engraver - all other epoxy and metal chip's markings are laser engraved.
« Last Edit: July 31, 2023, 08:27:35 pm by iMo »
Online Kleinstein
« Reply #249 on: July 31, 2023, 08:39:50 pm »
The relatively exotic plastics for the case could be tricky with conventional printing. With a relatively low volume product the laser labeling makes absolute sense, as there should be little fixed costs.
