Thanks MiDi we have got the first OPA189 buffer AC sim..
In actual use you might consider adding a small "protection" resistor in series with the Op-Amp - input, since this is "exposed" directly to the Output as shown in the schematic.
For added protection for reverse polarity a shunt diode across the output and Overvoltage protection a diode to the +15V supply (which may need a Shunt Zener and/or reverse diode to regulator input).
Anyway, these suggestions are just for protection against abuse which isn't necessary in most cases for the folks here.
Trying to get our hands on a ADR1001 to play around with, left a note at Analog Devices requesting such.
Best,
