Author Topic: Spread spectrum time domain reflectometry  (Read 2416 times)
Offline FaringdonTopic starter
« on: November 14, 2021, 09:28:32 pm »
When you’re doing Spread Spectrum Time domain reflectometry, and you want to inject frequencies from 93kHz to 24MHz into a cable (to see where it has a fault)…..what do you use to inject those frequencies into the cable?
It could be electrical cable, data cable, coaxial cable or shielded power distribution cable.
Why is the range of SSTDR longer in “ shielded power distribution cable”.
'Perfection' is the enemy of 'perfectly satisfactory'
Offline pqass
Re: Spread spectrum time domain reflectometry
« Reply #1 on: November 14, 2021, 10:35:24 pm »
I'm not sure about SS TDR but according to w2aew it's the fast edge that's important.
He uses a 74AC14 (because it has a fast 2ns edge) as a 6KHz pulse generator with 50 ohm resistor in-series into the cable under test
WRT TDR range, he said in another video, that TDR will only work on cable with a parallel return path (not sure how he put it).  ie. coax, twisted-pair, romex, etc.  I assume more of the signal is lost in the unshielded cable therefore less range as it is harder to see the return signal (having less amplitude).
« Last Edit: November 14, 2021, 10:45:21 pm by pqass »
The following users thanked this post: Faringdon
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: November 14, 2021, 10:40:33 pm »
Sounds more like testing the line with a sweep and watching for peaks/dips, than actual (sharp risetime) TDR.  Same underlying mechanism, but tested in the frequency domain.
What's so particular about 93kHz?  Is this something you were reading about?
Seven Transistor Labs, LLC
Offline tggzzz
« Reply #3 on: November 14, 2021, 11:10:09 pm »
What type of spread spectrum?
Why not just use a connector that matches whatever is on the cable?
Because your reference (which is hidden from us) says so.
Offline Bud
« Reply #4 on: November 15, 2021, 01:08:23 am »
We do not do spread spectrum time domain reflectometry.
Online ch_scr
« Reply #5 on: November 15, 2021, 07:35:02 am »
SSTDR is quote: A new and patented form of TDR https://www.livewireinnovation.com/sstdr/
Its benefits compared to normal TDR seem specialized to live wire circuits - the spread spectrum part allows to differentiate between the measurement pulses and whatever is going on on the wire otherwise.
I'd say it's a adaption of TDR for safety and security to continously monitor live wires, (hopefully) without interfering and without beeing interfered by normal use.
« Reply #6 on: November 15, 2021, 08:19:48 am »
Thanks yes, the product just said its range was over those frequencies.
Offline tggzzz
« Reply #7 on: November 15, 2021, 09:03:06 am »
And that answers Faringdon's question: use a capacitor.
Proposing to use these on aircraft in flight makes me shudder (my emphasis)):
The only way to locate these “small” faults, therefore, is to
locate them when they are (intermittently) nearly open or short
circuits
. This requires a system that can continuously test the
wires while they are live (and potentially in flight). STDR and
SSTDR have been shown to be effective for location of inter-
mittent faults on both analog (400 Hz) and digital (MilStd 1553)
systems.
Online David Hess
  • DavidH
« Reply #8 on: November 15, 2021, 07:46:34 pm »
TDR can be done with an impulse, an edge, a swept sine, or noise.  I do not know about now, but in the past there have been some time domain instruments which could use all of those methods.  VNAs which support TDR obviously use the swept sine method.  I do not remember what advantage if any the noise method has.
Online coppercone2
« Reply #9 on: November 16, 2021, 12:23:30 am »
the 93KHz is in a FCC band for cable locating IIRC, that method of cable location might also skip some frequencies as to avoid causing trouble for electrical equipment (band skip capability)
« Last Edit: November 16, 2021, 12:30:53 am by coppercone2 »
