Hi All,
I thought I might finally try to adjust my 5200A and I'm doing the full list - I'm at 4-71 Frequency Accuracy and Quadrature Level Calibration.
Para I. tells me to turn A2 & A3 in opposite directions to get an output of 9V-11V (I'm using a normal meter rather than a differential one on J65 if that matters) and nothing I do can get the level down to below 12.48V - Frequency I can get bang on to 800KHz.
Is there another adjustment I've missed or does this level just matter to devices I may connect to the quadrature out (J65)? IF so then I can safely move on at this stage because I don't have anything to connect to that.
Thanks,
TonyG
