Author Topic: A shunt for real currents  (Read 8169 times)
Offline Henrik_VTopic starter
  • “ground” is a convenient fantasy
« on: March 03, 2017, 02:20:30 pm »
Two pictures of a retirered 10µOhm shunt , 23kA  0.03%
to big for my collection  :'(
The small motor stirrs the coolant
« Last Edit: March 03, 2017, 02:55:33 pm by Henrik_V »
Greetings from Germany
Henrik
The number you have dialed is imaginary, please turn your phone 90° and dial again!
Offline poorchava
  • Troll Cave Electronics!
Re: A shunt for real currents
« Reply #1 on: March 03, 2017, 02:22:55 pm »
Pictures don't show, at least for me.
« Reply #2 on: March 03, 2017, 02:53:15 pm »
different source..
« Last Edit: March 03, 2017, 02:55:59 pm by Henrik_V »
Henrik
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 03, 2017, 03:05:20 pm »
Dang, and I just installed a meter on my aluminum smelting pot line!
Seven Transistor Labs, LLC
Offline Tom45
« Reply #4 on: March 03, 2017, 03:09:43 pm »
Two pictures of a retired 10µOhm shunt , 23kA  0.03%
Why was it retired? What did they replace it with?
Offline manganin
« Reply #5 on: March 03, 2017, 08:07:59 pm »
Otto Wolff
Offline babysitter
  • pushing silicon at work
« Reply #6 on: March 03, 2017, 09:25:42 pm »
... which is possibly some polychlorinated biphenyl
Great device, I would take it but only if its certified empty and cleaned. :)
What do you know about its history? Where was it, what kind of company, useage?
I'm not a feature, I'm a bug! ARC DG3HDA
Offline e61_phil
« Reply #7 on: March 03, 2017, 09:28:48 pm »
I would think it is from the PTB :)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #8 on: March 03, 2017, 09:31:44 pm »
Probably a shunt for railway since it says "gleichstrom" (DC).
Offline Vgkid
« Reply #9 on: March 03, 2017, 10:24:17 pm »
Wow, that is definitely a huge shunt.
Otto Wolff
I recognize those binding posts..
It is amazing what they were able to make back then, and how stable some of those standards are.
« Reply #10 on: March 03, 2017, 11:10:54 pm »
Where: PTB is rigth :)
But sorry, no idea about the history ... I'm in the acceleration dep.  ...
Otto Wolff
With your nick? :)   Probably yes, I check it next friday :D
It's marked to use native naphtha and water
No idea :) Maybe they changed the connector system ?   :D
Just a nice big stone of old metrology,  I don't know about the internal contstruction, but if it can take the dI/dt , you can measure the current of a thunderbold  8) ;D ;D
Well, (23kA)² x 10µ\$\Omega\$ = 5.29kW ...
« Last Edit: March 03, 2017, 11:18:58 pm by Henrik_V »
Henrik
Online HighVoltage
« Reply #11 on: March 05, 2017, 11:45:38 am »
Definitely big.
I have seen one of these in the Aluminum factory in Hamburg / Germany in the mid 1980s
This plant hat the largest power consumption in Hamburg.
And they got the power for (almost) free.
Offline Assafl
« Reply #12 on: March 05, 2017, 12:22:15 pm »
The shunt that shan't be used - no more. The shunt forever to be shunned - doomed by its own bigly-ness.
I guess those two thumbscrews are where you'd connect your Voltcraft DMM?
« Last Edit: March 05, 2017, 12:25:21 pm by Assafl »
Offline lowimpedance
  • Watts in an ohm?
« Reply #13 on: March 06, 2017, 12:25:38 am »
.......LOL............
Quite a few un loved ones stuck under benches around work here too!. Excellent door stops for very big doors  :D.
Offline Vgkid
« Reply #14 on: March 06, 2017, 03:28:45 am »
« Reply #15 on: March 06, 2017, 08:08:04 am »
DMM?
No, regarding the history a Weston-Element, a compensator and a lightbeam mirror galvanometer  ;D
or to cite Wildar:
Henrik
Offline Assafl
« Reply #16 on: March 06, 2017, 11:07:58 am »
DMM?
Ah yes - a Weston cell, a potentiometer and a null galvanometer (someone is selling a Guildline lightbeam galvanometer on eBay). I will be candid that until I started reading the metrology forum I never understood why a potentio-meter had "meter" as part of the word. Why not potentiovary or potentiotrol or something like that.
Is there a better way than a shunt to measure 23,000 Amps? How do they measure current at power stations? (I am just reading about Fiber Optic Current Sensors for measuring insane levels of DC current - really cool)
Offline Codebird
« Reply #17 on: March 06, 2017, 11:32:07 am »
These days, hall effect sensor. Those weren't around back in the Shunt Age, so you got monstrosities like that instead.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #18 on: March 06, 2017, 06:58:29 pm »
Nothing beats the bandwidth of a shunt.
https://www.utwente.nl/en/news/!/2017/3/313543/electronic-energy-meters-false-readings-almost-six-times-higher-than-actual-energy-consumption
For DC I still think shunts are used more. Hall effect sensors are easily offset by magnatic fields. This is why you should avoid LEM sensors at all cost.
« Last Edit: March 06, 2017, 07:00:40 pm by Jeroen3 »
Offline bji900
« Reply #19 on: March 06, 2017, 07:11:17 pm »
I would love to see the buss bars that connected this to the system and for that matter the system that it ran!
Offline Assafl
« Reply #20 on: March 06, 2017, 09:22:44 pm »
I read that Fibre Optic Fiber Sensors are replacing the big Hall Effect sensors. ABB talk about replacing Hall Effect sensors weighing 2 tons.
https://library.e.abb.com/public/74d5555d2a9c2998c12579a00038ff0a/FOCS_brochure_3BHS362996_E01.pdf
The Hall effect senor I got from Aliexpress weight a few grams.
Offline cncjerry
« Reply #21 on: March 19, 2017, 07:20:52 pm »
Where can I pick one of these up? It will go nicely with my other boat anchors.
