Author Topic: A portable box for 1/f and low noise measurements  (Read 1600 times)
Offline iMoTopic starter
  • Country: vc
« on: January 21, 2023, 11:13:18 am »
As I wrote once - in late 80ties I worked in a lab which messed with 1/f noise measurements. Within my diploma work I created a measurement chamber for the LNA and the samples with all the necessary batteries. The result - see below. Inside that box we had an additional copper foil inner box. There is a single 5mm dia hole for the coax.
What is funny a friend of mine, who works there at university, showed to me my decades old box yesterday - they found it while they did a cleanup of the labs, with an intention to carry it to scrapyard.. :palm: ..
Thus I've shot a couple of pictures - for a record - the box weights some 25-30kg (an estimate), a little bit rusty here and there, but still in an excellent condition..
 :D
« Last Edit: January 21, 2023, 11:16:08 am by imo »
Offline Gyro
Re: A portable box for 1/f and low noise measurements
« Reply #1 on: January 21, 2023, 11:26:34 am »
Yep, that ought to keep most stuff out! ;D
Best Regards, Chris
Online Andreas
« Reply #2 on: January 21, 2023, 11:31:12 am »
So you really avoided 50 Hz line noise hum  :-+
(which I have to test every time with a new set up).
with best regards
Andreas
Offline miro123
« Reply #3 on: January 21, 2023, 01:10:24 pm »
My outer chamber is ~4..5kg AL case - from chamber 1 to battery chamber #2 - the link is electrical - optocoupler insulated. second picture shows the optical fiber connection for the outside world.
Offline Overspeed
« Reply #4 on: January 21, 2023, 01:22:52 pm »
Hello
The old box looks to be a nice shit metal work made with professional skill .
To do it Quick and Dirty , that possible to built one '' double skin '' at good price with :
- Two ammo box as '' russian dolls ''  a 50 Cal / M2A1 Ammo Can to hold a 30 Cal / M19A1 Ammo Can
as ammo boxes are made in carbon steel box so that easy to TIG weld plate or even use rivets
- Two stainless steel box as used for surgical equipment sterilization
Regards
OS
The following users thanked this post: MrYakimovYA
  • Country: vc
« Reply #5 on: January 21, 2023, 04:36:18 pm »
It is not easy to shield 50Hz. Do the math - what kind of material and what thickness would you need in order to attenuate 50Hz x-times..
Offline DavidKo
  • Country: cz
« Reply #6 on: January 25, 2023, 12:08:49 pm »
So you need to come and move it alone to scrapyard,  since it does not have handles only sharp edges >:D. I must say nice mechanical work. I'm not sure if portable is the right word. It does include the trolley.
How it had performed in comparison with "standard" cookies box?
« Last Edit: January 25, 2023, 12:11:39 pm by DavidKo »
