source impedance, input signal level --> gain, and accuracy (16bit?)
Well as you may or may not have guessed I intent to build a multimeter,
so the source impedance can vary between near zero, if I was to measure a Power Supply
and near infinite, if I was to measure a specific resistor in a device.
But only the OP´s directly on the frontend are in charge of the very high impedance
Multimeters and other high input impedance instruments do not use chopper stabilized or automatic zero operational amplifiers because of the high current noise; they are simply not suitable for high input impedance applications.
The usual solution is to use a voltage follower, and then *if necessary* correct the offset of the voltage follower as part of the integration cycle, so essentially make an automatic zero amplifier that operates at a low frequency synchronously with the conversion cycle.
Additionally, if the offset is corrected at the input voltage, then the common mode rejection is corrected as well. This is why chopper stabilized and automatic zero operational amplifiers have high common mode rejection, and why CMOS voltage followers which have atrocious common mode rejection can be used with automatic zeroing.
I think we'd have to see the circuit to give the best recommendations. For example, there are some circuits where AZ isn't ideal and something like OPA140 is better.
The OPA140 would be my first choice. It has the right combination of input bias current, offset drift, noise, and common mode rejection ratio. In the past the LT1012 low input bias current bipolar part might have been used in the highest precision applications.
