Cheap Chinese TZT-TS01 NTP Server
A while ago i bought a Chinese TS01 NTP server, as a low power "Backup NTP Server".
I decided on this one.
TZT TS01 Network Time Server NTP Server for Beidou GPS GLONASS
https://www.aliexpress.com/item/1005005363401802.htmlIt's NOT TimeNuts material, and
won't really recommend it, unless you can live with the shortcommings.
Pros:Small
Cheap
Low Power
GPS receiver is sensitive.
Cons:It has a permanet offset around 130..140ms, from the other Stratum-1 NTP servers i use.
No DHCP , static ip only.
No Webinterface for configuring.
Windows Configre APP is in Chinese ONLY, so be prepared to play "Guess a setting/function".
The display shows the received time, but uses Beijung TZ - And i'm quite sure there's no way to change that.
Changing the ip address to one that fits my setup, was quite a challenge. Mostly due to it being in chinese.
Worst:You need to register the configure progrem key on an Internet server somewhere, before the program will connect to the NTP Box.
When you start the Configure program, it will show you a "register key seed", my guts tell me that seed ia generated from ie. "the pc's netcard mac address".
Then you have to go to the register server, and key in the "seed key", and you'll be shown the "activation key".
If that server disapears, you have no possibility to reregister on a new pc, and the box is useless.
It has been running for a month or so, wo. any issues besides the above.
But today i noticed that it had a "Reach of 0 , and a When of 92h", display shows normal , and LAN (traffic) is blinking.
I did power off, and a NTP restart - Now it's alive again.
NTP:My box is the kv-ntp....
ntpq -p
remote refid st t when poll reach delay offset jitter
-n1.taur.dk .PPS0. 1 u 46 128 377 6.738 0.180 0.354
-kv-ntp-01.luna- .GPS. 1 u 88 128 377 3.340 -167.05 1.919
+time.dfm.dk .DFM. 1 u 125 128 377 2.923 -0.027 0.203
*mmo2.ntp.netnod .PPS. 1 u 49 128 377 2.405 -0.085 0.448
+80.209.68.118.s .GPS. 1 u 134 128 377 4.223 0.026 0.136
-time.cloudflare 10.8.8.4 3 u 122 128 377 10.426 -0.453 0.247
-orange.inet.dk. 125.199.53.76 2 u 6 128 377 5.093 -0.104 0.104
Peerstats:My box is 10.xx.yy.zz
awk -f peer.awk peerstats.20230601
ident cnt mean rms max delay dist disp
192.36.143.130 57 0.161 0.271 0.837 10.310 24.938 16.366
194.58.204.148 56 0.049 0.181 0.712 2.091 20.658 16.621
10.xx.yy.zz 51 138.099 0.732 1.614 4.153 22.769 16.232
217.198.219.102 57 0.145 0.258 0.728 6.861 23.125 16.294
87.116.22.151 58 -0.032 0.167 0.610 2.871 21.130 16.477
If you are on a "tight budget" , and you can live with a 130+ ms offset , plus chinese app & risky registering.
Then it could be acceptable .... But i see others wo. the display, hat has a web config interface in english , and even seems to be cheaper.
/Bingo
