Hello all,
Bought a used Ohaus off ebay few months ago. 210 model. Was busy with work and have finally got around to setting it up. Realized that the tray ring was not included. Keep getting an error message after it goes through the self test cycle , "Err 8.2" which in the manual is listed as an internal power error and recommends just restarting the unit. Does not work for me sadly.
Is the tray ring essential to have for the tray to work properly, hence the error? When it's doing the self test cycle on startup i have it level , the sides and top of the tray area are covered blocking air pressure changes, and the tray and tray shield are inserted per manual instructions. Hope I'm not making a dumb mistake and missing something obvious
New to these devices, thought I would try here for some insight. Any help much appreciated.
