Greetings.
Having picked up a RAPCO (Pendulum) 2804B GPS-clock at a flea market, I posted a message searching for a manual
on the time-nuts mailing list. A user manual was kindly provided and it did help in starting the troubleshooting
procedure.
I am however stuck in trying to figure out why the frequency locking of the built-in OCXO does not work.
The control loop circuitry adresses an AD7846 - 16Bit Voltage Output DAC that controls the OCXO.
After indicating "Frequency Lock", the DAC output voltage goes from a value that sets the OCXO
close to 10 MHz, but then latches up and saturates at "99.9%" of the tuning range. This puts
the OCXO at 10.000.002 MHz...
I am presently investigating if the problem is the 7846 (Datasheet available) but if this
IC is good I don't think I can go any further.
Rapco was purchased by Orolia and then by Safran. The 2804 is obsolete since a long time
ago. I dont think approaching Safran would be successful. If anyone has more information
that the user manual, I would be grateful.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
