Author Topic: 3458A - black edition  (Read 48100 times)
Offline oPossum
Re: 3458A - black edition
« Reply #175 on: March 05, 2020, 01:54:14 am »
VFDs can be reliable, if done right.  I have a couple of 1970s era HP 59304A GPIB displays that use some type of gas discharge technology.
(Attachment Link)
Probably a Panaplex display. Similar technology to Nixie tubes but has a cathode for each segment rather than a cathode for an entire digit.
Offline TheSteve
  • Living the Dream
« Reply #176 on: March 19, 2020, 05:25:50 pm »
While we wait for high res pics we can at least see the new A3 in low-res courtesy of Keysight.
VE7FM
The following users thanked this post: Dr. Frank, Andreas, MiDi, MegaVolt, syau, Grandchuck
Offline syau
  • Country: hk
« Reply #177 on: March 20, 2020, 12:36:56 am »
U180 still there  :-DD
FPGA and associated 5V interface chips similar to those newer A3 board and the 8051 became SMD.
Offline MadTux
« Reply #178 on: March 20, 2020, 01:27:09 am »
What you could think of is *parallelizing* references for low noise. 10 chips ca. 1/3rd of the noise.
Why isn't this done on chip/die level already?
Like doing the LTZ1000 reference circuit like 16 times on a small ovenized chip assembly to get 4x lower noise than normal LTZ1000.
The following users thanked this post: engiadina
Online Kleinstein
« Reply #179 on: March 20, 2020, 08:42:48 am »
On chip level a larger area device can be used instead of multiple parallel one. AFAIK the LTFU already has 2 zener structures in parallel.
For the LTZ1000 more current for the reference also gives more heat and this requires a higher temperature or more power to the heater and possibly a different case design. In principle the LTZ1000 reference could run with a slightly higher current for lower noise - but with possible downside of more drift.
For a DMM 2 parallel references have an additional potential benefit over just noise reduction: 2 reference allow some basic consistency check to detect excessive drift of one reference. So it adds to the reliability.
Because the new boards are meant as a direct 1:1 replacement, a additional 2nd ref. board would be difficult to implement. The space and power would not be so bad, but it would also need some signal routing and different firmware. So this would be more like a point to the wish-list for a possible future new design.
Offline iMo
  • Country: bt
« Reply #180 on: March 20, 2020, 10:06:47 am »
I think the yield (the number of "good" chips/dies you get off a silicon wafer) with voltage references is low.
Therefore putting 16 references into a single chip (a single monolithic silicon die) would be risky and the yield would be much lower.
The good option would be a "hybrid chip device" or "multichip module" - ie. 16x LTZ1000 individually preselected dies put on a ceramic carrier, with some supporting stuff (thin/thick film technology), put into a larger hermetic metallic package.
« Last Edit: March 20, 2020, 10:08:55 am by imo »
Offline Henrik_V
  • “ground” is a convenient fantasy
« Reply #181 on: March 20, 2020, 03:04:07 pm »
Put 20 on the die, and offer a 4/8/16 version .. laser laser :D
Greetings from Germany
Henrik
The number you have dialed is imaginary, please turn your phone 90° and dial again!
Offline Macbeth
« Reply #182 on: March 21, 2020, 08:38:25 pm »
Is U180 still in production? I figured they had a finite supply of old stock but with a new board and meter are Keysight actually still getting them manufactured in that old school package?
Offline niner_007
« Reply #183 on: March 22, 2020, 03:00:32 am »
Of course it is in production, how could they still manufacture new meters or sell the bare boards, if they didn’t :palm:
Offline MadTux
« Reply #184 on: March 22, 2020, 12:09:26 pm »
New old stock, ie they made a big load of U180 dies during production run and stashed them somewhere?
Now they only need to package those. Once they run out of U180 dies, no more new 3458A?
Online Kleinstein
« Reply #185 on: March 22, 2020, 12:29:05 pm »
The U180 hybrid chip is a main part of the ADC. Redesigning this would be quite some effort with expensive testing. So it is absolutely no surprise to still find it. With the relatively large chips inside, the old THT case may also be a good choice for a hermetic case.
I don't know if they still have a current production or just sufficient NOS, either finished or just bare dies. The quantities are still small, so if won't be production every week anyway, more like every few years a new batch.
Just for the mounting holes and cable lengths they can't make the boards much smaller - so th new board picture is not such a large surprise. Staying rather close to the old version is natural even of the new chips are smaller.
Offline notfaded1
« Reply #186 on: March 22, 2020, 09:19:06 pm »
I don't see any reason why you wouldn't keep producing them... if it's not broke... don't fix it.  :-+
.ılılı..ılılı.
notfaded1
Offline e61_phil
« Reply #187 on: March 23, 2020, 09:04:04 am »
But it is...
The ADC drift problem seems to be a problem over many years now.
Online Kleinstein
« Reply #188 on: March 23, 2020, 09:47:02 am »
For the drift problem it is not so clear if this is really solved. It is also a relatively expensive part to produce.
So there are some arguments to avoid the U180 chip in a new design, but for the 3458 it is the essentially part for the ADC.
So no surprise to still see the old style U180 - it would not be a 3458 anymore without it.
Offline voltampere
« Reply #189 on: March 23, 2020, 05:43:21 pm »
Not really hires....
954864-0
But a bit clearer,
regards
Joerg
Online Dr. Frank
« Reply #190 on: March 23, 2020, 08:03:07 pm »
Many Thanks,  :-+
There's the Wekomm logo in the right bottom corner, a small non occupied 'test structure' beneath, probably a hex inverter 7404, 5 inverters in parallel, driving something, maybe a 'pigtail' optoisolator (U10).
No 8051 µP, instead that ALTERA CPLD, probably 5M1270Z, everything else as described.
Let's search, which fast comparator they've used..
Frank
« Last Edit: March 23, 2020, 08:58:21 pm by Dr. Frank »
Offline iMo
  • Country: bt
« Reply #191 on: March 23, 2020, 09:03:47 pm »
TL3016?
Offline branadic
  • Sounds like noise
« Reply #192 on: March 23, 2020, 09:18:18 pm »
Enough evidence that wekomm made this board, nice, thanks  :-+
Unpopulated Broadcom / Avago HFBR-1521Z and related logic gate for external clock.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Online Kleinstein
« Reply #193 on: March 23, 2020, 09:20:03 pm »
The comparators looks like TL3016 with additional clamping on the input, so they don't need a +-18 V supply. It is readable for U181.
This looks like a sensible choice.
The part around U181 still looks as odd as the original:  Buffer the signal with an LM358 to send it to a super fast comparator to drive a resistor of some 600 K.  :-//
This part of the circuit never made sense to me and chances are the comparator is disabled most of the time, except during some self tests.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #194 on: March 23, 2020, 11:18:28 pm »
Dr. Frank
8051 uC is little TQFP chipie with a label. So everything is there ;)
Offline chickenHeadKnob
« Reply #195 on: March 24, 2020, 01:08:06 am »
Where is the integrator cap? that part of the layout looks changed as well.
Online Kleinstein
« Reply #196 on: March 24, 2020, 11:39:26 am »
The integration cap is C119, right at the bottom of the board.
 There are some changes to the placement, but not really much. The general layout is similar.
There are also some changes to the circuit and values: e.g. 2 diodes each at the slope amplifier, larger resistors and thus a smaller capacitor at the output of the LT1001 in the integrator.
No longer the large decoupling caps (C120,C121) at the integrator (at least not on the top side - there could be an tantalum cap on the bottom, but I doubt it).
The following users thanked this post: chickenHeadKnob
Offline Echo88
« Reply #197 on: March 24, 2020, 11:54:42 am »
Is it correct that theyve never corrected the U180-microcrack-issue?
Offline iMo
  • Country: bt
« Reply #198 on: March 25, 2020, 12:01:02 pm »
Posters close to we-komm there in DE may ask them on U180 details..
Online Dr. Frank
« Reply #199 on: March 25, 2020, 12:59:20 pm »
The statement from Wekomm was (I think I already posted it here), that U180 is still in actual production by KS and has seen several revisions over the years.
The following users thanked this post: KaneTW
