Really broad question. IMHO, the best way to maintain them is not to disturb them. Temperature control can be air or oil- double air ovens have been used, like Julie Research did with theirs. It should be battery backed with a substantial capacity battery because recovery time is long. Most degradation probably comes from frequent over enthusiastic comparisons. Depending on what you need to do, comparisons once a month or even twice a year might be sufficient.
