Author Topic: Datron 4800 Series Option 70 Wideband Voltage Source  (Read 1420 times)
Offline perdrixTopic starter
« on: July 10, 2017, 05:57:05 pm »
Does anyone any data on Option 70 for the Datron 4808, the Wideband Voltage Source?
My 4808 has this bolted to the bottom but it needs to be connected to the main unit via two cables, so any information on those cables would be most welcome.   Any User or Service documentation for it would also be most helpful.
Thanks, Dave
Offline quarks
Re: Datron 4800 Series Option 70 Wideband Voltage Source
« Reply #1 on: July 11, 2017, 09:38:44 am »
the "Interface Loop Through" cables use SUB-D 15 and LEMO FGG.2B 306 connectors
PIN layout is documented in the manual (i.e. att. pic. for 4600 Connection)
